Precision, Selectable Gain, Fully Differential Funnel Amplifier
Pages / Page
24 /9 — Data Sheet. AD8475. +VS. 0.2. 0.4. 0.6. ) E. 0.8. V G. ( A. 1.0. G TL. G …
Revision
D
PDF / 555 Kb
Data Sheet. AD8475. +VS. 0.2. 0.4. 0.6. ) E. 0.8. V G. ( A. 1.0. G TL. G LTA. IN O. W VO. W V. S Y. –40°C. PPL. +25°C. GE P. +85°C. LTA SU. LTA. O O. +105°C. +125°C. V TO S
Data SheetAD8475+VS+VS0.20.20.40.4S0.6S0.6) E0.8)V GGE0.8V( A1.0(1.0G TLG LTAININ OW VOW VS YS–40°CLY–40°CGEPPPL+25°CGE P+25°C+85°CU+85°CLTA SULTAO O+105°CO+105°CT+125°CV TO S+125°CT VT DU EDU ETP RR1.0TP RER1.0OU0.8OU FEEF0.8ER0.6R0.60.40.40.20.2–VS–V 3 S1001k10k100k1M 01 10µA100µA1mA10mA100mA 014 32- RLOAD (Ω) 432- OUTPUT CURRENT (A) 09 094 Figure 11. Output Voltage Swing vs. RLOAD vs. Temperature, Figure 14. Output Voltage Swing vs. Output Current vs. Temperature, VS = ±5 V and +5 V VS = ±5 V and +5 V 0.8 × V10IN9p) p-8V (VEOUT7GLTA6IVO/DV T52VU TP4U O M3U IM X2A M1 1 05 2- 100µs/DIV 43 0 09 1001k10k100k1M10M 012 32- FREQUENCY (Hz) 094 Figure 12. Overdrive Recovery Figure 15. Maximum Output Voltage vs. Frequency –20100–3090G = 0.8–4080G = 0.4–5070B)B)dd(–6060RRRR (S PCM–7050–8040–9030–10020 1 6 100k1M10M 01 1k10k100k1M10M100M 21 2- 2- FREQUENCY (Hz) 43 FREQUENCY (Hz) 43 09 09 Figure 13. Power Supply Rejection Ratio (PSRR) vs. Frequency Figure 16. CMRR vs. Frequency Rev. D | Page 9 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION OVERVIEW CIRCUIT INFORMATION Output Common-Mode Voltage (VOCM) DC PRECISION INPUT VOLTAGE RANGE DRIVING THE AD8475 POWER SUPPLIES APPLICATIONS INFORMATION TYPICAL CONFIGURATION SINGLE-ENDED TO DIFFERENTIAL CONVERSION SETTING THE OUTPUT COMMON-MODE VOLTAGE HIGH PERFORMANCE ADC DRIVING AD8475 EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
