Datasheet ADL5562 (Analog Devices)
Description | 3.3 GHz Ultralow Distortion RF/IF Differential Amplifier |
Pages / Page | 21 / 1 — 3.3 GHz Ultralow Distortion. RF/IF Differential Amplifier. Data Sheet. … |
Revision | F |
File Format / Size | PDF / 566 Kb |
3.3 GHz Ultralow Distortion. RF/IF Differential Amplifier. Data Sheet. ADL5562. FEATURES. FUNCTIONAL BLOCK DIAGRAM
3.3 GHz Ultralow Distortion RF/IF Differential Amplifier Data Sheet ADL5562 FEATURES FUNCTIONAL BLOCK DIAGRAM −3 dB bandwidth of 3.3 GHz (AV = 6 dB) VCC Pin-strappable gain adjust: 6 dB, 12 dB, 15.5 dB RF Differential or single-ended input to differential output Low noise input stage: 2.1 nV/√Hz RTI at A ENBL V = 12 dB R Low broadband distortion (A G2 VON V = 6 dB) VIP2 10 MHz: −91 dBc HD2, −98 dBc HD3 RG1 70 MHz: −102 dBc HD2, −90 dBc HD3 VIP1 VCOM RG1 140 MHz: −104 dBc HD2, −87 dBc HD3 VIN1 250 MHz: −80 dBc HD2, −94 dBc HD3 RG2 VOP IMD3s of −94 dBc at 250 MHz center VIN2 Slew rate: 9.8 V/ns R Fast settling of 2 ns and overdrive recovery of 3 ns F ADL5562
001
Single-supply operation: 3 V to 3.6 V GND
08003-
Power-down control
Figure 1.
Fabricated using the high speed XFCB3 SiGe process APPLICATIONS Differential ADC drivers Single-ended to differential conversion RF/IF gain blocks SAW filter interfacing GENERAL DESCRIPTION
The ADL5562 is a high performance differential amplifier The device is optimized for wideband, low distortion optimized for RF and IF applications. The amplifier offers low performance. These attributes, together with its adjustable gain noise of 2.1 nV/√Hz and excellent distortion performance over capability, make this device the amplifier of choice for general- a wide frequency range, making it an ideal driver for high speed purpose IF and broadband applications where low distortion, 8-bit to 16-bit ADCs. noise, and power are critical. This device is optimized for the The ADL5562 provides three gain levels of 6 dB, 12 dB, and best combination of slew speed, bandwidth, and broadband 15.5 dB through a pin-strappable configuration. For the single- distortion. These attributes allow it to drive a wide variety of ended input configuration, the gains are reduced to 5.6 dB, analog-to-digital converters (ADCs) and make it ideally suited 11.1 dB, and 14.1 dB. Using an external series input resistor for driving mixers, pin diode attenuators, SAW filters, and expands the amplifier gain flexibility and allows for any gain multi-element discrete devices. selection from 0 dB to 15.5 dB. Fabricated on an Analog Devices, Inc., high speed SiGe process, The quiescent current of the ADL5562 is typically 80 mA and, the ADL5562 is supplied in a compact 3 mm × 3 mm, 16-lead when disabled, consumes less than 3 mA, offering excellent LFCSP package and operates over the temperature range of input-to-output isolation. −40°C to + 85°C.
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2009–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output GAIN ADJUSTMENT AND INTERFACING ADC INTERFACING LAYOUT CONSIDERATIONS SOLDERING INFORMATION EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
