Datasheet ADA4938-1/ADA4938-2 (Analog Devices) - 8
DescriptionUltralow Distortion Differential ADC Driver (Dual)
Pages / Page26 / 8 — ADA4938-1/ADA4938-2. Data Sheet. PIN CONFIGURATIONS AND FUNCTION …
File Format / SizePDF / 605 Kb
ADA4938-1/ADA4938-2. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. –FB 1. 12 PD. –IN1 1. 18 +OUT1. +IN 2. 11 –OUT. ADA4938-1
ADA4938-1/ADA4938-2 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS –FB 1 12 PD –IN1 1 18 +OUT1 +IN 2 11 –OUT ADA4938-1
ADA4938-1/ADA4938-2 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS S S S S 1 1 T –V –V –V –V 1 1 1 B S S 1 U N 6 I F V V D O 1 51 41 31 + P 4 3 2 1 0 2 2 2 2 9 2 1 –FB 1 12 PD –IN1 1 18 +OUT1 +IN 2 11 –OUT ADA4938-1 +FB1 2 17 VOCM1 –IN 3 TOP VIEW 10 +OUT +V 3 ADA4938-2 16 S1 –VS2 (Not to Scale) +V 4 TOP VIEW 15 –V +FB 4 9 V S1 S2 OCM (Not to Scale) –FB2 5 14 PD2 5 6 7 8 +IN2 6 13 –OUT2 S S S S +V +V +V +V 7 8 9 01 11 21 2 2 2 2 NOTES 2 2 N B S S M T 1. THE EXPOSED PAD IS NOT ELECTRICALLY CONNECTED I– F V V C U + + + O TO THE DEVICE. IT IS TYPICALLY SOLDERED TO GROUND
03
O
0
V + OR A POWER PLANE ON THE PCB THAT IS THERMALLY
2-
CONDUCTIVE.
659
NOTES
0
06
22-
659
CONDUCTIVE.
0 Figure 5. ADA4938-1 Pin Configuration Figure 6. ADA4938-2 Pin Configuration
Table 7. ADA4938-1 Pi n Function Descriptions Table 8. ADA4938-2 Pi n Function Descriptions Pin No. Mnemonic Description Pin No. Mnemonic Description
1 −FB Negative Output Feedback Pin. 1 −IN1 Negative Input Summing Node 1. 2 +IN Positive Input Summing Node. 2 +FB1 Positive Output Feedback Pin 1. 3 −IN Negative Input Summing Node. 3, 4 +VS1 Positive Supply Voltage 1. 4 +FB Positive Output Feedback Pin. 5 −FB2 Negative Output Feedback Pin 2. 5 to 8 +VS Positive Supply Voltage. 6 +IN2 Positive Input Summing Node 2. 9 VOCM Output Common-Mode Voltage. 7 −IN2 Negative Input Summing Node 2. 10 +OUT Positive Output for Load Connection. 8 +FB2 Positive Output Feedback Pin 2. 11 −OUT Negative Output for Load Connection. 9, 10 +VS2 Positive Supply Voltage 2. 12 PD Power-Down Pin. 11 VOCM2 Output Common-Mode Voltage 2. 13 to 16 −VS Negative Supply Voltage. 12 +OUT2 Positive Output 2. EP Exposed Paddle. The exposed pad is not 13 −OUT2 Negative Output 2. electrically connected to the device. It is 14 PD2 Power-Down Pin 2. typically soldered to ground or a power plane on the PCB that is 15, 16 −VS2 Negative Supply Voltage 2. thermally conductive. 17 VOCM1 Output Common-Mode Voltage 1. 18 +OUT1 Positive Output 1. 19 −OUT1 Negative Output 1. 20 PD1 Power-Down Pin 1. 21, 22 −VS1 Negative Supply Voltage 1. 23 −FB1 Negative Output Feedback Pin 1. 24 +IN1 Positive Input Summing Node 1. EP Exposed Paddle. The exposed pad is not electrically connected to the device. It is typically soldered to ground or a power plane on the PCB that is thermally conductive. Rev. B | Page 8 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION ±DIN to ±OUT Performance VOCM to ±OUT Performance SINGLE-SUPPLY OPERATION ±DIN to ±OUT Performance VOCM to ±OUT Performance ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUTS TERMINOLOGY THEORY OF OPERATION ANALYZING AN APPLICATION CIRCUIT SETTING THE CLOSED-LOOP GAIN ESTIMATING THE OUTPUT NOISE VOLTAGE THE IMPACT OF MISMATCHES IN THE FEEDBACK NETWORKS CALCULATING THE INPUT IMPEDANCE OF AN APPLICATION CIRCUIT INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS TERMINATING A SINGLE-ENDED INPUT SETTING THE OUTPUT COMMON-MODE VOLTAGE LAYOUT, GROUNDING, AND BYPASSING HIGH PERFORMANCE ADC DRIVING OUTLINE DIMENSIONS ORDERING GUIDE
