Datasheet ADA4937-1/ADA4937-2 (Analog Devices) - 8
DescriptionUltralow Distortion Differential ADC Driver (Dual)
Pages / Page28 / 8 — ADA4937-1/ADA4937-2. Data Sheet. PIN CONFIGURATIONS AND FUNCTION …
RevisionF
File Format / SizePDF / 598 Kb
ADA4937-1/ADA4937-2. Data Sheet. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. N1I. –IN1 1. 18 +OUT1. –FB 1. 12 PD. +FB1 2. 17 VOCM1. +IN 2
ADA4937-1/ADA4937-2 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS N1I –IN1 1 18 +OUT1 –FB 1 12 PD +FB1 2 17 VOCM1 +IN 2
ADA4937-1/ADA4937-2 Data Sheet PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS 1 S S S S B1 S1 S1 UT N1I D1 –V –V –V –V + –F –V –V P –O 16 15 14 13 24 23 22 21 20 19 –IN1 1 18 +OUT1 –FB 1 12 PD +FB1 2 17 VOCM1 +IN 2 ADA4937-1 11 –OUT +V 3 ADA4937-2 16 S1 –VS2 TOP VIEW TOP VIEW –IN 3 10 +OUT +V 15 –V (Not to Scale) 4 S1 S2 (Not to Scale) –FB2 5 14 +FB 4 9 V PD2 OCM +IN2 6 13 –OUT2 5 6 7 8 7 8 9 S S S S 10 11 12 +V +V +V +V 2 N2 B2 S2 S2 T2 NOTES F CM –I + +V +V O 1. EXPOSED PADDLE. THE EXPOSED PAD IS NOT V OU + ELECTRICALLY CONNECTED TO THE DEVICE. IT IS
005
NOTES TYPICALLY SOLDERED TO GROUND OR A POWER 1. EXPOSED PADDLE. THE EXPOSED PAD IS NOT PLANE ON THE PCB THAT IS THERMALLY CONDUCTIVE.
06591-
006
TYPICALLY SOLDERED TO GROUND OR A POWER PLANE ON THE PCB THAT IS THERMALLY CONDUCTIVE.
06591- Figure 5. ADA4937-1 Pin Configuration Figure 6. ADA4937-2 Pin Configuration
Table 7. ADA4937-1 P in Function Descriptions Table 8. ADA4937-2 P in Function Descriptions Pin No. Mnemonic Description Pin No. Mnemonic Description
1 −FB Negative Output for Feedback 1 −IN1 Negative Input Summing Node 1. Component Connection. 2 +FB1 Positive Output Feedback Pin 1. 2 +IN Positive Input Summing Node. 3, 4 +V 3 −IN Negative Input Summing Node. S1 Positive Supply Voltage 1. 5 −FB2 Negative Output Feedback Pin 2. 4 +FB Positive Output for Feedback Component Connection. 6 +IN2 Positive Input Summing Node 2. 5 to 8 +V 7 −IN2 Negative Input Summing Node 2. S Positive Supply Voltage. 9 V 8 +FB2 Positive Output Feedback Pin 2. OCM Output Common-Mode Voltage. 10 +OUT Positive Output for Load Connection. 9, 10 +VS2 Positive Supply Voltage 2. 11 −OUT Negative Output for Load Connection. 11 VOCM2 Output Common-Mode Voltage 2. 12 PD 12 +OUT2 Positive Output 2. Power-Down Pin. 13 −OUT2 Negative Output 2. 13 to 16 −VS Negative Supply Voltage. 14 EP Exposed Paddle. The exposed pad is not PD2 Power-Down Pin 2. electrical y connected to the device. It is 15, 16 −VS2 Negative Supply Voltage 2. typically soldered to ground or a power 17 VOCM1 Output Common-Mode Voltage 1. plane on the PCB that is thermally 18 +OUT1 Positive Output 1. conductive. 19 −OUT1 Negative Output 1. 20 PD1 Power-Down Pin 1. 21, 22 −VS1 Negative Supply Voltage 1. 23 −FB1 Negative Output Feedback Pin 1. 24 +IN1 Positive Input Summing Node 1. EP Exposed Paddle. The exposed pad is not electrical y connected to the device. It is typically soldered to ground or a power plane on the PCB that is thermal y conductive. Rev. F | Page 8 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS 5 V OPERATION ±DIN to ±OUT Performance VOCM to ±OUT Performance 3.3 V OPERATION ±DIN to ±OUT Performance VOCM to ±OUT Performance ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION ANALYZING AN APPLICATION CIRCUIT SETTING THE CLOSED-LOOP GAIN ESTIMATING THE OUTPUT NOISE VOLTAGE IMPACT OF MISMATCHES IN THE FEEDBACK NETWORKS CALCULATING THE INPUT IMPEDANCE FOR AN APPLICATION CIRCUIT Terminating a Single-Ended Input INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE POWER-DOWN OPERATION LAYOUT, GROUNDING, AND BYPASSING HIGH PERFORMANCE ADC DRIVING 3.3 V OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
