Datasheet AD8137 (Analog Devices) - 2
DescriptionLow Cost, Low Power Differential ADC Driver
Pages / Page33 / 2 — AD8137* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
File Format / SizePDF / 612 Kb
AD8137* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8137* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• AD-FMCMOTCON2-EBZ Evaluation Board • MT-075: Differential Drivers for High Speed ADCs • Universal Evaluation Board for Single Differential Overview Amplifiers • MT-076: Differential Driver Analysis • MT-218: Multiple Feedback Band-Pass Design Example
DOCUMENTATION Application Notes DESIGN RESOURCES
• AN-0990: Terminating a Differential Amplifier in Single- • AD8137 Material Declaration Ended Input Applications • PCN-PDN Information • AN-0992: Active Filter Evaluation Board for Differential • Quality And Reliability Amplifiers • Symbols and Footprints • AN-1026: High Speed Differential ADC Driver Design Considerations
DISCUSSIONS
• AN-1363: Meeting Biasing Requirements of Externally Biased RF/Microwave Amplifiers with Active Bias View all AD8137 EngineerZone Discussions. Controllers • AN-282: Fundamentals of Sampled Data Systems
SAMPLE AND BUY
• AN-584: Using the AD813X Differential Amplifier Visit the product page to see pricing options. • AN-649: Using the Analog Devices Active Filter Design Tool
TECHNICAL SUPPORT Data Sheet
Submit a technical question or find your regional support • AD8137: Low Cost, Low Power, Differential ADC Driver number. Data Sheet
User Guides DOCUMENT FEEDBACK
• UG-474: Evaluation Board for Differential Amplifiers Submit feedback for this data sheet. Offered in 8-Lead SOIC Packages
TOOLS AND SIMULATIONS
• ADI DiffAmpCalc™ • AD8137 SPICE Macro-Model
Document Outline Features Applications Functional Block Diagram General Descripton Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Applications Information Analyzing a Typical Application with Matched RF and RG Networks Typical Connection and Definition of Terms Output Balance Estimating Noise, Gain, and Bandwith with Matched Feedback Networks Estimating Output Noise Voltage and Bandwidth Voltage Gain Feedback Factor Notation Input Common-Mode Voltage Calculating Input Impedance Input Common-Mode Swing Considerations Bandwidth vs. Closed-Loop Gain Estimating DC Errors Additional Impact of Mismatches in the Feedback Networks Driving a Capacitive Load Layout Considerations Terminating a Single-Ended Input Power-Down Driving an ADC with Greater than 12-Bit Performance Outline Dimensions Ordering Guide Automotive Products
