Datasheet AD8132 (Analog Devices) - 4
DescriptionLow Cost, High Speed Differential Amplifier
Pages / Page33 / 4 — AD8132. REVISION HISTORY 9/09—Rev. H to Rev. I. 11/05—Rev. D to Rev. E. …
RevisionI
File Format / SizePDF / 518 Kb
AD8132. REVISION HISTORY 9/09—Rev. H to Rev. I. 11/05—Rev. D to Rev. E. 5/09—Rev. G to Rev. H. 12/04—Rev. C to Rev. D
AD8132 REVISION HISTORY 9/09—Rev H to Rev I 11/05—Rev D to Rev E 5/09—Rev G to Rev H 12/04—Rev C to Rev D
AD8132 REVISION HISTORY 9/09—Rev. H to Rev. I 11/05—Rev. D to Rev. E
Changes to Figure 64 Caption .. 21 Changes to Table 7, Thermal Resistance Section, Maximum
Power Dissipation Section, and Figure 3 .. 8 Changes to Features Section, Applications Section, and General Changes to Ordering Guide .. 29 Description Section .. 1
Changes to Table 1 ... 4 Changes to General Description .. 1 Changes to Table 2 ... 5 Changes to Specifications ... 2 Changes to Table 3 ... 6 Changes to Absolute Maximum Ratings... 8 Changes to Table 4 ... 7 Updated Outline Dimensions ... 29 Added Automotive Products Section .. 29 Changes to Ordering Guide .. 29 Changes to Ordering Guide .. 30
2/03—Rev. B to Rev. C 1/09—Rev. F to Rev. G
Changes to Specifications ... 2 Changes to Figure 77 ... 26 Addition to Estimating the Output Noise Voltage Section .. 15 Updated Outline Dimensions ... 29 Updated Outline Dimensions ... 21
11/06—Rev. E to Rev. F 1/02—Rev. A to Rev. B
Updated Format ... Universal Edits to Transmitter Equalizer Section ... 18 Changes to Table 1 ... 3 Changes to Table 4 ... 6 Changes to Table 5 ... 7 Changes to Ordering Guide .. 29 Rev. I | Page 3 of 32 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OPERATIONAL DESCRIPTION DEFINITION OF TERMS Differential Voltage Common-Mode Voltage BASIC CIRCUIT OPERATION THEORY OF OPERATION GENERAL USAGE OF THE AD8132 DIFFERENTIAL AMPLIFIER WITHOUT RESISTORS (HIGH INPUT IMPEDANCE INVERTING AMPLIFIER) OTHER β2 = 1 CIRCUITS VARYING β2 β1 = 0 ESTIMATING THE OUTPUT NOISE VOLTAGE CALCULATING INPUT IMPEDANCE OF THE APPLICATION CIRCUIT INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD OPEN-LOOP GAIN AND PHASE LAYOUT, GROUNDING, AND BYPASSING CIRCUITS APPLICATIONS INFORMATION ANALOG-TO-DIGITAL DRIVER BALANCED CABLE DRIVER TRANSMIT EQUALIZER LOW-PASS DIFFERENTIAL FILTER HIGH COMMON-MODE OUTPUT IMPEDANCE AMPLIFIER FULL-WAVE RECTIFIER AUTOMOTIVE PRODUCTS OUTLINE DIMENSIONS ORDERING GUIDE
