Datasheet AD8132 (Analog Devices) - 6
DescriptionLow Cost, High Speed Differential Amplifier
Pages / Page33 / 6 — AD8132. VOCM TO ±OUT SPECIFICATIONS. Table 2. Parameter Conditions. Min. …
RevisionI
File Format / SizePDF / 518 Kb
AD8132. VOCM TO ±OUT SPECIFICATIONS. Table 2. Parameter Conditions. Min. Typ. Max. Unit
AD8132 VOCM TO ±OUT SPECIFICATIONS Table 2 Parameter Conditions Min Typ Max Unit
link to page 21 link to page 21
At TA = 25°C, VS = ±5 V, VOCM = 0 V, G = +1, RL, dm = 499 Ω, RF = RG = 348 Ω, unless otherwise noted. For G = +2, RL, dm = 200 Ω, RF = 1000 Ω, RG = 499 Ω. Refer to Figure 56 and Figure 57 for test setup and label descriptions. All specifications refer to single-ended input and differential outputs, unless otherwise noted.
Table 2. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth ΔVOCM = 600 mV p-p 210 MHz Slew Rate ΔVOCM = −1 V to +1 V 400 V/μs Input Voltage Noise (RTI) f = 0.1 MHz to 100 MHz 12 nV/√Hz DC PERFORMANCE Input Voltage Range ±3.6 V Input Resistance 50 kΩ Input Offset Voltage VOS, cm = VOUT, cm; VDIN+ = VDIN− = VOCM = 0 V ±1.5 ±7 mV AD8132W only, TMIN to TMAX ±9 mV Input Bias Current 0.5 μA VOCM CMRR ΔVOUT, dm/ΔVOCM; ΔVOCM = ±1 V; resistors matched to 0.01% −68 dB Gain ΔVOUT, cm/ΔVOCM; ΔVOCM = ±1 V 0.985 1 1.015 V/V AD8132W only, TMIN to TMAX 0.985 1.015 V/V POWER SUPPLY Operating Range ±1.35 ±5.5 V Quiescent Current VDIN+ = VDIN− = VOCM = 0 V 11 12 13 mA AD8132W only, TMIN to TMAX 9 14.5 mA TMIN to TMAX variation 16 μA/°C Power Supply Rejection Ratio ΔVOUT, dm/ΔVS; ΔVS = ±1 V −70 −60 dB AD8132W only, TMIN to TMAX −60 dB OPERATING TEMPERATURE RANGE −40 +125 °C Rev. I | Page 5 of 32 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OPERATIONAL DESCRIPTION DEFINITION OF TERMS Differential Voltage Common-Mode Voltage BASIC CIRCUIT OPERATION THEORY OF OPERATION GENERAL USAGE OF THE AD8132 DIFFERENTIAL AMPLIFIER WITHOUT RESISTORS (HIGH INPUT IMPEDANCE INVERTING AMPLIFIER) OTHER β2 = 1 CIRCUITS VARYING β2 β1 = 0 ESTIMATING THE OUTPUT NOISE VOLTAGE CALCULATING INPUT IMPEDANCE OF THE APPLICATION CIRCUIT INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD OPEN-LOOP GAIN AND PHASE LAYOUT, GROUNDING, AND BYPASSING CIRCUITS APPLICATIONS INFORMATION ANALOG-TO-DIGITAL DRIVER BALANCED CABLE DRIVER TRANSMIT EQUALIZER LOW-PASS DIFFERENTIAL FILTER HIGH COMMON-MODE OUTPUT IMPEDANCE AMPLIFIER FULL-WAVE RECTIFIER AUTOMOTIVE PRODUCTS OUTLINE DIMENSIONS ORDERING GUIDE
