AD8131* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSTOOLS AND SIMULATIONS View a parametric search of comparable parts. • AD8131 SPICE Macro-Model EVALUATION KITSREFERENCE MATERIALS • Universal Evaluation Board for Single Differential Product Selection Guide Amplifiers • Amplifiers for Video Distribution • High Speed Amplifiers Selection Table DOCUMENTATIONApplication NotesDESIGN RESOURCES • AN-356: User's Guide to Applying and Measuring • AD8131 Material Declaration Operational Amplifier Specifications • PCN-PDN Information • AN-357: Operational Integrators • Quality And Reliability • AN-584: Using the AD813X Differential Amplifier • Symbols and Footprints • AN-589: Ways to Optimize the Performance of a Difference Amplifier DISCUSSIONS • AN-649: Using the Analog Devices Active Filter Design Tool View all AD8131 EngineerZone Discussions. • AN-692: Universal Precision Op Amp Evaluation Board SAMPLE AND BUYData Sheet • AD8131: Low-Cost, High-Speed Differential Driver Data Visit the product page to see pricing options. Sheet User GuidesTECHNICAL SUPPORT • UG-474: Evaluation Board for Differential Amplifiers Submit a technical question or find your regional support Offered in 8-Lead SOIC Packages number. • UG-888: Evaluation Board for Differential Amplifiers Offered in 8-Lead MSOP Packages DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OPERATIONAL DESCRIPTION THEORY OF OPERATION ANALYZING AN APPLICATION CIRCUIT CLOSED-LOOP GAIN ESTIMATING THE OUTPUT NOISE VOLTAGE CALCULATING THE INPUT IMPEDANCE OF AN APPLICATION CIRCUIT INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD APPLICATIONS TWISTED-PAIR LINE DRIVER 3 V SUPPLY DIFFERENTIAL A-TO-D DRIVER UNITY-GAIN, SINGLE-ENDED-TO-DIFFERENTIAL DRIVER OUTLINE DIMENSIONS ORDERING GUIDE
