Datasheet AD8138-EP (Analog Devices) - 9
DescriptionLow Distortion Differential ADC Driver
Pages / Page12 / 9 — AD8138-EP. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +IN. VOCM 2. …
File Format / SizePDF / 195 Kb
AD8138-EP. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +IN. VOCM 2. +OUT. –OUT. NC = NO CONNECT
AD8138-EP PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –IN +IN VOCM 2 +OUT –OUT NC = NO CONNECT
AD8138-EP PIN CONFIGURATION AND FUNCTION DESCRIPTIONS AD8138-EP –IN 1 8 +IN VOCM 2 7 NC V+ 3 6 V– +OUT 4 5 –OUT
01 0 7-
NC = NO CONNECT
99 08 Figure 6. Pin Configuration
Table 7. Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input Summing Node. 2 VOCM Voltage applied to this pin sets the common-mode output voltage with a ratio of 1:1. For example, 1 V dc on VOCM sets the dc bias level on +OUT and −OUT to 1 V. 3 V+ Positive Supply Voltage. 4 +OUT Positive Output. Note that the voltage at −DIN is inverted at +OUT. 5 −OUT Negative Output. Note that the voltage at +DIN is inverted at –OUT. 6 V− Negative Supply Voltage. 7 NC No Connect. 8 +IN Positive Input Summing Node. Rev. 0 | Page 9 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION MAXIMUM OUTPUT VOLTAGE SWING PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
