Datasheet AD8421-EP (Analog Devices) - 5
Description3 nV /√Hz, Low Power Instrumentation Amplifier
Pages / Page20 / 5 — Enhanced Product. AD8421-EP. Parameter. Test Conditions/ Comments. Min. …
File Format / SizePDF / 505 Kb
Enhanced Product. AD8421-EP. Parameter. Test Conditions/ Comments. Min. Typ. Max. Unit
Enhanced Product AD8421-EP Parameter Test Conditions/ Comments Min Typ Max Unit
link to page 8
POWER SUPPLY Operating Range Dual supply ±2.5 ±18 V Single supply 5 36 V Quiescent Current 2 2.3 mA Over Temperature TA = −55°C to +125°C 2.8 mA TEMPERATURE RANGE For Specified Performance −55 +125 °C 1 Total voltage noise = √(e 2 2 ni + (eno/G)2 + eRG ). See the AD8421 data sheet for more information. 2 Total RTI VOS = (VOSI) + (VOSO/G). 3 These specifications do not include the tolerance of the external gain setting resistor, RG. For G > 1, add RG errors to the specifications given in this table. 4 Input voltage range of the AD8421-EP input stage only. The input range can depend on the common-mode voltage, differential voltage, gain, and reference voltage. See the Typical Performance Characteristics section for more information. Rev. 0 | Page 5 of 20 Document Outline Features Enhanced Product Features Pin Connection Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Outline Dimensions Ordering Guide
