Datasheet AD8421 (Analog Devices) - 2
Description3 nV /√Hz, Low Power Instrumentation Amplifier
Pages / Page14 / 2 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/13625
File Format / SizePDF / 162 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/13625
1. SCOPE 1.1 Scope. This drawing documents the general requirements of a high performance low power instrumentation amplifier microcircuit, with an operating temperature range of -55°C to +125°C. 1.2 Vendor Item Drawing Administrative Control Number. The manufacturer’s PIN is the item of identification. The vendor item drawing establishes an administrative control number for identifying the item on the engineering documentation: V62/13265 - 01 X E Drawing Device type Case outline Lead finish number (See 1.2.1) (See 1.2.2) (See 1.2.3) 1.2.1 Device type(s). Device type Generic Circuit function 01 AD8421-EP Low power instrumentation amplifier 1.2.2 Case outline(s). The case outline(s) are as specified herein. Outline letter Number of pins JEDEC PUB 95 Package style X 8 MO-187-AA Plastic small outline 1.2.3 Lead finishes. The lead finishes are as specified below or other lead finishes as provided by the device manufacturer: Finish designator Material A Hot solder dip B Tin-lead plate C Gold plate D Palladium E Gold flash palladium Z Other
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/13625
REV PAGE 2 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/13625 REV
