Datasheet AD8293G80, AD8293G160 (Analog Devices) - 6
DescriptionLow Cost, Zero-Drift In-Amp with Filter and Fixed Gain = 80
Pages / Page16 / 6 — AD8293G80/AD8293G160. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. …
File Format / SizePDF / 395 Kb
AD8293G80/AD8293G160. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. AD8293Gxx. –IN. +IN. GND. +VS. REF. OUT. ADC OUT. FILT. TOP VIEW
AD8293G80/AD8293G160 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS AD8293Gxx –IN +IN GND +VS REF OUT ADC OUT FILT TOP VIEW
link to page 11
AD8293G80/AD8293G160 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS AD8293Gxx –IN 1 8 +IN GND 2 7 +VS REF 3 6 OUT 4 5 ADC OUT FILT
03 0 1-
TOP VIEW
45
(Not to Scale)
07 Figure 3. Pin Configuration
Table 6. Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Inverting Input Terminal (True Differential Input) 2 GND Ground 3 REF Reference Voltage Terminal (Drive This Terminal to Level-Shift the Output) 4 ADC OUT Output with Series 5 kΩ Resistor for Use with an Antialiasing Filter 5 FILT Place a capacitor across FILT and OUT to limit the amount of switching noise at the output (see Applications Information) 6 OUT Output Terminal Without Integrated Filter 7 +VS Positive Power Supply Terminal 8 +IN Noninverting Input Terminal (True Differential Input) Rev. 0 | Page 6 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION HIGH PSR AND CMR 1/f NOISE CORRECTION APPLICATIONS INFORMATION OVERVIEW REFERENCE CONNECTION OUTPUT FILTERING CLOCK FEEDTHROUGH POWER SUPPLY BYPASSING INPUT OVERVOLTAGE PROTECTION OUTLINE DIMENSIONS ORDERING GUIDE
