Datasheet AD8253 (Analog Devices) - 2
Description10 MHz, G = 1, 10, 100, 1000 iCMOS Programmable Gain Instrumentation Amplifier
Pages / Page25 / 2 — AD8253* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 480 Kb
AD8253* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE DESIGNS. EVALUATION KITS
AD8253* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE DESIGNS EVALUATION KITS
View a parametric search of comparable parts. • CN0260 • CN0359
EVALUATION KITS
• AD8253 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• High-performance Adder Uses Instrumentation Amplifiers
Application Notes
• AN-1401: Instrumentation Amplifier Common-Mode
DESIGN RESOURCES
Range: The Diamond Plot • AD8253 Material Declaration
Data Sheet
• PCN-PDN Information • AD8253: 10 MHz, 20 V/μs, G = 1, 10, 100, 1000 iCMOS • Quality And Reliability Programmable Gain Instrumentation Amplifier Data Sheet • Symbols and Footprints
Technical Books
• A Designer's Guide to Instrumentation Amplifiers, 3rd
DISCUSSIONS
Edition, 2006 View all AD8253 EngineerZone Discussions.
User Guides
• UG-928: Evaluating the AD8253 10 MHz 20 V/μs, G = 1, 10,
SAMPLE AND BUY
100, 1000, iCMOS Programmable Gain Instrumentation Amplifier Visit the product page to see pricing options.
TOOLS AND SIMULATIONS TECHNICAL SUPPORT
• AD8253 SPICE Macro Model Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION GAIN SELECTION Transparent Gain Mode Latched Gain Mode Timing for Latched Gain Mode POWER SUPPLY REGULATION AND BYPASSING INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION REFERENCE TERMINAL COMMON-MODE INPUT VOLTAGE RANGE LAYOUT Grounding Coupling Noise Common-Mode Rejection RF INTERFERENCE DRIVING AN ANALOG-TO-DIGITAL CONVERTER APPLICATIONS INFORMATION DIFFERENTIAL OUTPUT SETTING GAINS WITH A MICROCONTROLLER DATA ACQUISITION OUTLINE DIMENSIONS ORDERING GUIDE
