Datasheet AD8220 (Analog Devices) - 9
DescriptionJFET Input Instrumentation Amplifier with Rail-to-Rail Output in MSOP Package
Pages / Page29 / 9 — AD8220. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. 2.00. 1.75. …
RevisionC
File Format / SizePDF / 586 Kb
AD8220. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. 2.00. 1.75. N (. 1.50. IO AT. IP S. 1.25. R DI. 1.00. E W O P. 0.75. UM IM. 0.50. AX M. 0.25
AD8220 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating 2.00 1.75 N ( 1.50 IO AT IP S 1.25 R DI 1.00 E W O P 0.75 UM IM 0.50 AX M 0.25
link to page 9 link to page 11 link to page 9 link to page 9 link to page 9
AD8220 ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress Supply Voltage ±18 V rating only; functional operation of the device at these or any Power Dissipation See Figure 3 other conditions above those indicated in the operational Output Short-Circuit Current Indefinite1 section of this specification is not implied. Exposure to absolute Input Voltage (Common Mode) ±Vs maximum rating conditions for extended periods may affect Differential Input Voltage ±Vs device reliability. Storage Temperature Range −65°C to +125°C Figure 3 shows the maximum safe power dissipation in the Operating Temperature Range2 −40°C to +125°C package vs. the ambient temperature for the MSOP on a 4-layer Lead Temperature (Soldering 10 sec) 300°C JEDEC standard board. θJA values are approximations. Junction Temperature 140°C θJA (4-Layer JEDEC Standard Board) 135°C/W
2.00
Package Glass Transition Temperature 140°C ESD (Human Body Model) 4 kV
) 1.75 W
ESD (Charge Device Model) 1 kV
N ( 1.50
ESD (Machine Model) 0.4 kV
IO AT IP S 1.25
1 Assumes the load is referenced to midsupply.
S
2 Temperature for specified performance is −40°C to +85°C. For performance
R DI 1.00
to 125°C, see the Typical Performance Characteristics section.
45 0 9-
0
357 0
–40 –20 0 20 40 60 80 100 120 AMBIENT TEMPERATURE (°C)
Figure 3. Maximum Power Dissipation vs. Ambient Temperature
ESD CAUTION
Rev. B | Page 8 of 28 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Gain Selection Layout Common-Mode Rejection Ratio (CMRR) Grounding Reference Terminal Power Supply Regulation and Bypassing Input Bias Current Return Path Input Protection RF Interference Common-Mode Input Voltage Range Driving an ADC Applications Information AC-Coupled Instrumentation Amplifier Differential Output Electrocardiogram Signal Conditioning Outline Dimensions Ordering Guide Automotive Products
