Datasheet AD8230 (Analog Devices) - 6
Description16 V Rail-to-Rail, Zero-Drift, Precision Instrumentation Amplifier
Pages / Page17 / 6 — AD8230. ABSOLUTE MAXIMUM RATINGS. Table 3. THERMAL CHARACTERISTICS. …
RevisionB
File Format / SizePDF / 371 Kb
AD8230. ABSOLUTE MAXIMUM RATINGS. Table 3. THERMAL CHARACTERISTICS. Parameter Rating. Table 4. Parameter Value. Unit. ESD CAUTION
AD8230 ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL CHARACTERISTICS Parameter Rating Table 4 Parameter Value Unit ESD CAUTION
AD8230 ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL CHARACTERISTICS Parameter Rating
Specification is for device in free air SOIC. Supply Voltage ±8 V, +16 V
Table 4.
Internal Power Dissipation 304 mW
Output Short-Circuit Current 20 mA Input Voltage (Common-Mode) ±V θJA (4-Layer JEDEC Board) 121 °C/W S Differential Input Voltage ±VS Storage Temperature Range −65°C to +150°C
ESD CAUTION
Operational Temperature Range −40°C to +125°C Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. B | Page 5 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING THE GAIN LEVEL-SHIFTING THE OUTPUT SOURCE IMPEDANCE AND INPUT SETTLING TIME INPUT VOLTAGE RANGE INPUT PROTECTION POWER SUPPLY BYPASSING POWER SUPPLY BYPASSING FOR MULTIPLE CHANNEL SYSTEMS LAYOUT APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
