17 /8 — AD8225. 1000. 130. 120. 110. 100. CMR – dB 70. NOISE DENSITY – nV/ E G. …
Revision
A
PDF / 309 Kb
AD8225. 1000. 130. 120. 110. 100. CMR – dB 70. NOISE DENSITY – nV/ E G. LTA. 10k. 100k. FREQUENCY – Hz. 0.10. 0.08. 0.06. 0.04. 0.02. TI –. –0.02. NOISE – R
AD82251000130120Hz1101009010080CMR – dB 70NOISE DENSITY – nV/ E G60LTA50VO400301101001k10k1101001k10k100kFREQUENCY – HzFREQUENCY – Hz TPC 7. Input Current Noise Spectral Density vs. TPC 10. CMR vs. Frequency, RTI Frequency 0.1041S0.0830.06100290C0.04V10.02TI –00–1–0.02NOISE – R–2CMRR DRIFT – ppm/ –0.04100–0.06–3–0.08–4–0.100510–40–20020406080100TIME – secTEMPERATURE – C TPC 8. 0.1 Hz to 10 Hz Voltage Noise, RTI TPC 11. CMRR vs. Temperature 1581SVS = 15V610100– V490GE A5T2OLVS = 5V00–2–510–4CURRENT NOISE – 2pA/divCOMMON-MODE V0–10–6–8–15–15–10–50510150510OUTPUT VOLTAGE – VTIME – sec TPC 9. 0.1 Hz to 10 Hz Current Noise TPC 12. CMV Range vs. VOUT, Dual Supplies REV. A –7– Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN FUNCTION DESCRIPTIONS ORDERING GUIDE Typical Performance Characteristics Test Circuits THEORY OF OPERATION 47pF 2 5 200mV APPLICATIONS Precision V-to-I Converter Driving a High Resolution ADC Using the Reference Input AD8225 Used as an EKG Front End Benefits of Fast Slew Rates Evaluation Board OUTLINE DIMENSIONS Revision History
