Datasheet AD627 (Analog Devices) - 8
DescriptionMicropower, Single and Dual Supply R/R Instrumentation Amplifier
Pages / Page25 / 8 — Data Sheet. AD627. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter. Rating. …
RevisionE
File Format / SizePDF / 995 Kb
Data Sheet. AD627. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter. Rating. ESD CAUTION
Data Sheet AD627 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 8
Data Sheet AD627 ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress Supply Voltage ±18 V rating only; functional operation of the device at these or any other conditions above those indicated in the operational Internal Power Dissipation1 section of this specification is not implied. Exposure to absolute PDIP (N-8) 1.3 W maximum rating conditions for extended periods may affect SOIC_N (R-8) 0.8 W device reliability. −IN, +IN −VS − 20 V to +VS + 20 V Common-Mode Input Voltage −VS − 20 V to +VS + 20 V Differential Input Voltage (+IN − (−IN)) +VS − (−VS)
ESD CAUTION
Output Short-Circuit Duration Indefinite Storage Temperature Range (N, R) −65°C to +125°C Operating Temperature Range −40°C to +85°C Lead Temperature (Soldering, 10 sec) 300°C 1 Specification is for device in free air: 8-lead PDIP package: θJA = 90°C/W. 8-lead SOIC_N package: θJA = 155°C/W. Rev. E | Page 7 of 24 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Single Supply Dual Supply Dual and Single Supplies Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Using the AD627 Basic Connections Setting the Gain Reference Terminal Input Range Limitations in Single-Supply Applications Output Buffering Input and Output Offset Errors Make vs. Buy: A Typical Application Error Budget Errors Due to AC CMRR Ground Returns for Input Bias Currents Layout and Grounding Input Protection RF Interference Applications Circuits Classic Bridge Circuit 4 mA to 20 mA Single-Supply Receiver Thermocouple Amplifier Outline Dimensions Ordering Guide
