TABLE I. Electrical performance characteristics - Continued. Conditions 1/ 2/ Test Symbol -55C TA +125C Group A Device Limits Unit unless otherwise specified subgroups type Min Max Input voltage V IN Differential, linear, 3/ 1 01 10 V G = 1, TA = 25C Common mode, linear 3/ 7 G = 1, TA = 25C Differential, safe, 36 TA = 25C 3/ 5/ 6/ Common, safe, 36 TA = 25C 3/ 5/ 6/ 1/ Devices supplied to this drawing have been characterized through all levels M, D, P, L, R of irradiation. However, this device is only tested at the “R” level. Pre and Post irradiation values are identical unless otherwise specified in table I. VS = 15 V, RL = 2 k, unless otherwise specified. 2/ These parts may be dose rate sensitive in a space environment and may demonstrate enhanced low dose rate effects. Radiation end point limits for the noted parameters are guaranteed only for the conditions as specified in MIL-STD-883, method 1019, condition A. 3/ This parameter not tested post radiation. 4/ Power supply voltage tested at 15 V with a swing to 12 V. 5/ Input voltage (differential, safe) is the maximum voltage difference that can exist between the two input pins without damage to the device. Input voltage (common mode, safe) is the maximum voltage that can be applied to both input pins at the same time without damage to the device. The addition of the differential and common mode voltages shall not exceed 36 volts and can be applied when the device power is on or off without damage to the device. 6/ Guaranteed if not tested to the limits specified. STANDARD SIZE 5962-88539MICROCIRCUIT DRAWINGA DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 G 7 DSCC FORM 2234 APR 97
