Datasheet ADUM4190 (Analog Devices) - 10
DescriptionHigh Stability Isolated Error Amplifier
Pages / Page21 / 10 — Data Sheet. ADuM4190. 100. –20. d N (. E (m. –40. O -L. T V E. PEN. –60. …
File Format / SizePDF / 520 Kb
Data Sheet. ADuM4190. 100. –20. d N (. E (m. –40. O -L. T V E. PEN. –60. O P. OFFS. –80. –100. 120. 140. TEMPERATURE (°C). 1.05. 1.04. ) V m. V) 1.03. (V/. OLTA. IN A
Data Sheet ADuM4190 100 –20 d N ( E (m –40 O -L T V E PEN –60 O P OFFS –80 –100 120 140 TEMPERATURE (°C) 1.05 1.04 ) V m V) 1.03 (V/ OLTA IN A
Data Sheet ADuM4190 100 0 90 –20 B) V) d N ( E (m AI G G 80 A –40 P LT O O O -L T V E 70 PEN –60 O P OFFS UT AM O P 60 –80 O EA 50 –100 –40 –20 0 20 40 60 80 100 120 140
010
013
TEMPERATURE (°C)
1336-
TEMPERATURE (°C)
1336- 1 1 Figure 10. Op Amp Open-Loop Gain vs. Temperature Figure 13. EAOUT Offset Voltage vs. Temperature
1.05 100 1.04 ) V m 50 ( GE V) 1.03 (V/ OLTA IN A 0 T V G E UT 1.02 O EA OFFS 2 UT –50 O 1.01 EA 1.00 –100
1
1 0
114
TEMPERATURE (°C)
1336-
TEMPERATURE (°C)
1 11336- Figure 11. EAOUT Gain vs. Temperature Figure 14. EAOUT2 Offset Voltage vs. Temperature
2.66 2.64 1 V) 2.62 (V/ IN A G 2 UT 2.60 O 2 EA 2.58 2.56
015
112
CH1 10mV Ω CH2 10mV Ω M4.0µs A CH1 1.18V T 102.4ns
1336-
TEMPERATURE (°C)
1 11336- Figure 12. EAOUT2 Gain vs. Temperature Figure 15. Output Noise with Test Circuit 1 (10 mV/DIV), Channel 1 = EAOUT, Channel 2 = EAOUT2 Rev. 0 | Page 9 of 20 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Package Characteristics Regulatory Information Insulation and Safety Related Specifications Recommended Operating Conditions DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 Insulation Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Applications Information Accuracy Circuit Operation Isolated Amplifier Circuit Operation Application Block Diagram Setting the Output Voltage DOSA Module Application DC Correctness and Magnetic Field Immunity Insulation Lifetime Outline Dimensions Ordering Guide
