Datasheet ADUM4190-EP (Analog Devices) - 4
DescriptionHigh Stability Isolated Error Amplifier
Pages / Page14 / 4 — ADuM4190-EP. Enhanced Product. Parameter. Test Conditions/Comments. Min. …
File Format / SizePDF / 483 Kb
ADuM4190-EP. Enhanced Product. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. PACKAGE CHARACTERISTICS. Table 2. Parameter
ADuM4190-EP Enhanced Product Parameter Test Conditions/Comments Min Typ Max Unit PACKAGE CHARACTERISTICS Table 2 Parameter
link to page 9 link to page 9 link to page 4 link to page 7
Power Supply Rejection DC, V = V = 3.0 V to 20 V 60 dB DD1 DD2 Supply Current I See Figure 4 1.4 2.0 mA DD1 I See Figure 5 2.9 5.0 mA DD2 1 Output gain is defined as the slope of the best-fit line of the output voltage vs. the input voltage over the specified input range, with the offset error adjusted out. 2 Output linearity is defined as the peak-to-peak output deviation from the best-fit line of the output gain, expressed as a percentage of the full-scale output voltage.
PACKAGE CHARACTERISTICS Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
RESISTANCE Input to Output1 R 1013 Ω I-O CAPACITANCE Input to Output1 C 2.2 pF f = 1 MHz I-O Input Capacitance2 C 4.0 pF I IC JUNCTION-TO-AMBIENT THERMAL RESISTANCE θ 45 °C/W Thermocouple located at center of package JA underside 1 The device is considered a 2-terminal device; Pin 1 through Pin 8 are shorted together, and Pin 9 through Pin 16 are shorted together. 2 Input capacitance is from any input pin to ground.
REGULATORY INFORMATION
The ADuM4190-EP is pending approval by the organizations listed in Table 3. See Table 8 for recommended maximum working voltages for specific cross-isolation waveforms and insulation levels.
Table 3. UL (Pending) CSA (Pending) VDE (Pending) CQC (Pending)
Recognized under UL 1577 Approved under CSA Component Certified according to DIN V VDE V Certified by CQC11-471543-2015, Component Recognition Acceptance Notice 5A 0884-10 (VDE V 0884-10):2006-122 GB4943.1-2011 Program1 Single Protection, Reinforced insulation per CSA Reinforced insulation, 849 V peak Reinforced insulation at 400 V rms 5000 V rms Isolation 60950-1-03 and IEC 60950-1, (565 V peak), tropical climate, Voltage, 16-Lead SOIC 400 V rms (565 V peak) maximum altitude ≤ 5000 meters working voltage Basic insulation per CSA 60950-1-03 and IEC 60950-1, 800 V rms (1131 V peak) maximum working voltage Certified temperature range: Certified temperature range: Certified temperature range: Certified temperature range: −40°C to +125°C −40°C to +125°C −40°C to +125°C −40°C to +125°C File E214100 File 205078 File 2471900-4880-0001 File CQC15001129480 1 In accordance with UL 1577, each ADuM4190-EP is proof tested by applying an insulation test voltage ≥ 6000 V rms for 1 sec (current leakage detection limit = 10 µA). 2 In accordance with DIN V VDE V 0884-10 (VDE V 0884-10):2006-12, each ADuM4190-EP is proof tested by applying an insulation test voltage ≥ 1590 V peak for 1 sec (partial discharge detection limit = 5 pC). The asterisk (*) marking branded on the component designates DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 approval. Rev. 0 | Page 4 of 14 Document Outline FEATURES ENHANCED FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY RELATED SPECIFICATIONS RECOMMENDED OPERATING CONDITIONS DIN V VDE V 0884-10 (VDE V 0884-10):2006-12 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
