Datasheet ADUM3190 (Analog Devices) - 10
Description2.5kV rms Isolated Error Amplifier
Pages / Page19 / 10 — Data Sheet. ADuM3190. TYPICAL PERFORMANCE CHARACTERISTICS. 1.228. VDDx = …
File Format / SizePDF / 596 Kb
Data Sheet. ADuM3190. TYPICAL PERFORMANCE CHARACTERISTICS. 1.228. VDDx = 20V. VDDx = 5V. 1.227. (V) 1.226. ) A (m. 1.225. I DD1. ACCURAC
Data Sheet ADuM3190 TYPICAL PERFORMANCE CHARACTERISTICS 1.228 VDDx = 20V VDDx = 5V 1.227 (V) 1.226 ) A (m 1.225 I DD1 ACCURAC
Data Sheet ADuM3190 TYPICAL PERFORMANCE CHARACTERISTICS 3 1.228 VDDx = 20V VDDx = 5V 1.227 2 (V) 1.226 Y ) A (m 1.225 I DD1 ACCURAC UT 1 OF 1.224 RE 1.223 0 1.222 –40 –20 0 20 40 60 80 100 120 140
017
020
TEMPERATURE (°C)
1335- 1
TEMPERATURE (°C)
1335- 1 Figure 4. Typical IDD1 Supply Current vs. Temperature Figure 7. REFOUT Accuracy vs. Temperature
5 1.0 VDDx = 20V VDDx = 5V 4 0.5 %) ( Y 3 mA) ( 0 I DD2 ACCURAC 2 UT O EA –0.5 1 0 –1.0 –40 –20 0 20 40 60 80 100 120 140
018
021
TEMPERATURE (°C)
1335-
TEMPERATURE (°C)
1335- 1 1 Figure 5. Typical IDD2 Supply Current vs. Temperature Figure 8. EAOUT Accuracy vs. Temperature
12 3 10 2 V) A) n ( E (m 8 G 1 NT A LT O 6 T V CURRE 0 E AS BI 4 OFFS UT –1 P INP AM P 2 O –2 0 –3 –40 –20 0 20 40 60 80 100 120 140
019
022
TEMPERATURE (°C)
1335- 1
TEMPERATURE (°C)
1335- 1 Figure 6. +IN, −IN Input Bias Current vs. Temperature Figure 9. Op Amp Offset Voltage vs. Temperature Rev. A | Page 9 of 18 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Package Characteristics Regulatory Information Insulation and Safety Related Specifications Recommended Operating Conditions DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Applications Information Theory of Operation Accuracy Circuit Operation Isolated Amplifier Circuit Operation Application Block Diagram Setting the Output Voltage DOSA Module Application DC Correctness and Magnetic Field Immunity Insulation Lifetime Packaging and Ordering Information Outline Dimensions Ordering Guide Automotive Products
