Datasheet ADL5910 (Analog Devices) - 6
DescriptionDC to 6 GHz, ≤45 dB Envelope Threshold Detector/Trigger
Pages / Page22 / 6 — ADL5910. Data Sheet. Parameter. Test Conditions/Comments. Min Typ. Max. …
ADL5910. Data Sheet. Parameter. Test Conditions/Comments. Min Typ. Max. Unit
ADL5910 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
POWER-DOWN INTERFACE ENBL pin Voltage Level To Enable 2 VPOS V To Disable 0 0.6 V Input Bias Current VENBL = 2.2 V <20 nA POWER SUPPLY INTERFACE VPOS pin Supply Voltage 3.15 3.3 3.45 V Quiescent Current TA = 25°C, no signal at RFIN 3.5 mA TA = 105°C, no signal at RFIN 4 mA Power-Down Current ENBL = low 100 µA 1 The slash indicates a range. For example, −0.3/0 means −0.3 to 0. Rev. 0 | Page 6 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION A COMPLETE INPUT PROTECTION CIRCUIT RESET ON ENABLE OR AT POWER-UP IMPROVING FREQUENCY FLATNESS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
