Datasheet ADL5910 (Analog Devices) - 9
DescriptionDC to 6 GHz, ≤45 dB Envelope Threshold Detector/Trigger
Pages / Page22 / 9 — Data Sheet. ADL5910. TYPICAL PERFORMANCE CHARACTERISTICS. 0.01GHz. …
Data Sheet. ADL5910. TYPICAL PERFORMANCE CHARACTERISTICS. 0.01GHz. 0.03GHz. 0.1GHz. 0.9GHz. RFIN. 1.9GHz. 2.6GHz. 3.6GHz. 5.8GHz. 2pF. 0pF
Data Sheet ADL5910 TYPICAL PERFORMANCE CHARACTERISTICS 0.01GHz 0.03GHz 0.1GHz 0.9GHz RFIN 1.9GHz 2.6GHz 3.6GHz 5.8GHz 2pF 0pF
VPOS = 3.3 V, input levels referred to 50 Ω source. Input RF signal is a sine wave (CW), unless otherwise noted.
10 0.01GHz 0.03GHz 0.1GHz 0.9GHz RFIN 1.9GHz 1 2.6GHz 3 3.6GHz 5.8GHz ) 2pF 0pF (V – 0.1 INV 0.01 10pF 100pF Q 2 0.001
5
–40 –35 –30 –25 –20 –15 –10 –5 0 5 10 15 20
03 39
CH2 1.0V Ω M10ns 20GSPS A CH2 400mV
0 7- 7-
CH3 100mV Ω T 50ps/pt
383
P
1
IN (dBm)
83 13 Figure 3. VIN− vs. PIN at Various Frequencies Figure 6. Q Output Response vs. Load Capacitance, PIN = Off to −10 dBm, Overdrive Threshold Voltage Set to Trigger at −11 dBm (Overdrive Level = 1 dB, VIN− = 65 mV)
RFIN RFIN 3 3 Q Q 2 2
36
CH2 1.0V Ω M10ns 20GSPS A CH2 1.52V
033
0 37- 37-
CH3 500mV Ω T 20ps/pt CH3 1.0V Ω
138 138 Figure 4. Q Output Response, PIN = Off to 6 dBm, Figure 7. Q Output Response, PIN = Off to 10 dBm, VIN− (400 mV) Set to Trigger at 5 dBm (Overdrive Level = 1 dB) VIN− (400 mV) Set to Trigger at 5 dBm (Overdrive Level = 5 dB)
4 7
-03
-03
CH3 100mV Ω T 20ps/pt
837
CH3 100mV Ω
3837 13 1 Figure 5. Q Output Response, PIN = Off to −9 dBm, Overdrive Threshold Figure 8. Q Output Response, PIN = Off to −5 dBm, Overdrive Threshold Voltage Set to Trigger at −10 dBm (Overdrive Level = 1 dB, VIN− = 75 mV) Voltage Set to Trigger at −10 dBm (Overdrive Level = 5 dB, VIN− = 75 mV) Rev. 0 | Page 9 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS Q AND QB RESPONSE TIME SETTING THE VIN− THRESHOLD DETECTION VOLTAGE APPLICATIONS INFORMATION A COMPLETE INPUT PROTECTION CIRCUIT RESET ON ENABLE OR AT POWER-UP IMPROVING FREQUENCY FLATNESS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
