Datasheet HMC1030LP5E (Analog Devices) - 6
DescriptionDual RMS Power Detector SMT, Single-Ended, DC - 3.9 GHz
Pages / Page39 / 6 — HMC1030LP5E. DUAL RMS POWER DETECTOR. DC - 3.9 GHz. Electrical …
File Format / SizePDF / 5.0 Mb
HMC1030LP5E. DUAL RMS POWER DETECTOR. DC - 3.9 GHz. Electrical Specifications III. ET [A, B] Outputs. VSET [A,B] Outputs
HMC1030LP5E DUAL RMS POWER DETECTOR DC - 3.9 GHz Electrical Specifications III ET [A, B] Outputs VSET [A,B] Outputs
HMC1030LP5E
v03.1113
(continued), TA = +25 °C, VCCA = VCCB = VCCBS = 5V, Sci3 = Sci1 = 0V, Sci2 = 5V, Unless Otherwise Noted Parameter Conditions Min. Typ. Max. Units
ET [A, B] Outputs
Modulation Bandwidth 100 MHz Output Voltage Range 1 to 2.1 V Measured with 0.9 GHz input RF signal Source/Sink Current Compliance 8 / 2.95 mA at -18 dBm power Output Slew Rate (rise/fall) 83.3 / 250 106 V/sec
VSET [A,B] Outputs
For control applications with nominal 11 Input Voltage Range [1] 0.13 to 2.7 V slope/intercept settings Input Resistance 1 kOhm
OUTP and OUTN Outputs
Output Voltage Range R =1k Ohm, C =4.7pF [1] 1 to 3.9 V T L L OUTP-FBKA and OUTN-FBKB 0.1 to M Open-loop Output Voltage Range V disconnected for control applications Vcc-0.9 S Measured with 0.9 GHz input RF signal Source/Sink Current Compliance 8 / 2.2 mA at -30 dBm power -
VLVL, Common Mode Reference Level for OUT[P,N]
Voltage Range OUT[P,N]=FBK[A,B] 0 5 V RS Input Resistance 6 kOhm O
V
T
REF2, Voltage Reference Output
Output Voltage 2.43 V C Temperature Sensitivity 0.15 mV/°C TE Source/Sink Current Compliance 5.5 / 2.6 mA E
TEMP, Temperature Sensor Output
Output Voltage measured at 0°C 0.6 V D Temperature Sensitivity 2.2 mV/°C R Source/Sink Current Compliance 1.7 / 0.5 mA
SCI1-3 Inputs, ENX Logic Input, Power Down Control
WE Input High Voltage 0.7xV V CC O Input Low Voltage 0.3xV V CC P Input Capacitance 0.5 pF
Power Supply
Supply Voltage 4.5 5 5.5 V 120.6 mA nominal at -40°C; Supply Current with no input power 143 mA 159.5 mA nominal at 85°C 128 mA nominal at -40°C; Supply Current with 0 dBm at one channel 151.7 mA 168.2 mA nominal at 85°C Supply Current with 0 dBm at both channels 160 mA Standby Mode Supply Current 13 mA [1] For nominal slope/intercept setting, please see application section to change this range Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
11 - 5
Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
