Datasheet HMC1013LP4E (Analog Devices)
Description67 dB SMT SDLVA, 0.5 - 18.5 GHz
Pages / Page10 / 1 — HMC1013LP4E. SUCCESSIVE DETECTION LOG VIDEO. AMPLIFIER (SDLVA), 0.5 - …
File Format / SizePDF / 776 Kb
HMC1013LP4E. SUCCESSIVE DETECTION LOG VIDEO. AMPLIFIER (SDLVA), 0.5 - 18.5 GHz. Typical Applications. Features
Datasheet HMC1013LP4E Analog Devices
HMC1013LP4E
v02.0913
SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA), 0.5 - 18.5 GHz Typical Applications Features
The HMC1013LP4E is ideal for: High Logging Range: 67 dB (-62 to +5 dBm) • EW, ELINT & IFM Receivers Output Frequency Flatness: ±2 dB T • DF Radar Systems Log Linearity: ±2 dB M • ECM Systems Fast Rise/Fal Times: 5/15 ns S • Broadband Test & Measurement - Single Positive Supply: +3.3V • Power Measurement & Control Circuits ESD Sensitivity (HBM): Class 1A As • Military & Space Applications 24 Lead 4x4mm SMT Package: 16mm2 LV
Functional Diagram
SD
General Description
The HMC1013LP4E is a Successive Detection Log Video Amplifier which operates from 0.5 to 18.5 GHz. The HMC1013LP4E provides a logging range of 67 dB. This device offers typical fast rise/fall times of 5/15 ns and a superior delay time of only 10 ns. The HMC1013LP4E log video output slope is typical y 15 mV/dB. Maximum recovery times are less than 40 ns. The HMC1013LP4E is available in a highly com- pact 4x4 mm SMT plastic package and is ideal for high speed channelized receiver applications.
Electrical Specifications, TA = +25 °C Vcc1 = Vcc2 = Vcc3= +3.3V, EN=3.3V
Parameter Conditions Typ. Units Input Frequency Range [1] 0.5 - 18.5 GHz Frequency Flatness ±2 dB Log Linearity Pin = -60 to +5 dBm ±2 dB Log Linearity over Temperature ±2 dB Minimum Logging Range to ±3 dB error -62 dBm Maximum Logging Range to ±3 dB error +5 dBm Input Return Loss 8 dB Log Video Minimum Output Voltage 0.9 V Log Video Maximum Output Voltage 1.9 V Log Video Output Rise Time 10% to 90% 5 ns Log Video Output Fall Time 90% to 10% 15 ns Log Video Recovery Time @ 10 GHz 38 ns Log Video Output Slope 15 mV/dB Log Video Output Slope Variation over Temperature @ 10 GHz 6.2 µV/dB°C Log Video Propagation Delay 10 ns Supply Current (Icc1) 7 mA Supply Current (Icc2) 90 mA Supply Current (Icc3) 86 mA [1] Video output load should be 1K Ohm or higher. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
