Datasheet ADL5505 (Analog Devices) - 5
Description450 MHz TO 6000 MHz TruPwr™ Detector
Pages / Page22 / 5 — ADL5505. SPECIFICATIONS. Table 1. Parameter. Test Conditions. Min. Typ. …
RevisionA
ADL5505. SPECIFICATIONS. Table 1. Parameter. Test Conditions. Min. Typ. Max. Unit
ADL5505 SPECIFICATIONS Table 1 Parameter Test Conditions Min Typ Max Unit
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
TA = 25°C, VS = 3.0 V, COUT = open, light condition ≤ 600 lux, 75 Ω input termination resistor, unless otherwise noted.
Table 1. Parameter Test Conditions Min Typ Max Unit
FREQUENCY RANGE Input RFIN 450 6000 MHz RF INPUT (f = 450 MHz) Input RFIN to output VRMS Input Impedance No termination 510||1.01 Ω||pF RMS Conversion Dynamic Range1 Continuous wave (CW) input, −40°C < TA < +85°C ±0.25 dB Error2 Delta from 25°C 25 dB ±0.25 dB Error3 16 dB ±1 dB Error3 36 dB ±2 dB Error3 40 dB Maximum Input Level ±0.25 dB error3 15 dBm Minimum Input Level ±1 dB error3 −22 dBm Conversion Gain VRMS = (gain × VIN) + intercept 1.88 V/V rms Output Intercept4 0.008 V Output Voltage, High Input Power PIN = 5 dBm, 400 mV rms 0.755 V Output Voltage, Low Input Power PIN = −15 dBm, 40 mV rms 0.082 V Temperature Sensitivity PIN = 0 dBm +25°C < TA < +85°C 0.0027 dB/°C −40°C < TA < +25°C 0.0024 dB/°C RF INPUT (f = 900 MHz) Input RFIN to output VRMS Input Impedance No termination 370||0.80 Ω||pF RMS Conversion Dynamic Range1 Continuous wave (CW) input, −40°C < TA < +85°C ±0.25 dB Error2 Delta from 25°C 26 dB ±0.25 dB Error3 17 dB ±1 dB Error3 36 dB ±2 dB Error3 40 dB Maximum Input Level ±0.25 dB error3 15 dBm Minimum Input Level ±1 dB error3 −23 dBm Conversion Gain VRMS = (gain × VIN) + intercept 1.6 1.86 2.2 V/V rms Output Intercept4 −0.1 +0.009 +0.1 V Output Voltage, High Input Power PIN = 5 dBm, 400 mV rms 0.748 V Output Voltage, Low Input Power PIN = −15 dBm, 40 mV rms 0.083 V Temperature Sensitivity PIN = 0 dBm +25°C < TA < +85°C 0.0026 dB/°C −40°C < TA < +25°C 0.0024 dB/°C Rev. A | Page 3 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Output Low-Pass Filter Power Consumption Device Calibration and Error Calculation Calibration for Improved Accuracy Drift Over a Reduced Temperature Range Device Handling Land Pattern and Soldering Information Evaluation Board Outline Dimensions Ordering Guide
