Datasheet HMC813LC4B (Analog Devices) - 10
DescriptionSUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 20 GHz
Pages / Page10 / 10 — HMC813LC4B. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH …
File Format / SizePDF / 902 Kb
HMC813LC4B. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH LIMITED RF OUTPUT, 1 - 20 GHz. Evaluation PCB
HMC813LC4B SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 20 GHz Evaluation PCB
HMC813LC4B
v03.0614
T M S - RS O T C E T E D R E W O P
List of Materials for Evaluation PCB 131679 [1]
Item Description J1, J2 K-Type Connector J3 SMA Connector The circuit board used in the application should J4 - J6 DC Pins use RF circuit design techniques. Signal lines sho- 100 nF Ultra-Wideband Capacitor, 0402 uld have 50 ohm impedance while the package C1, C2, C4 Pkg. ATC ATC545L104KW16T ground leads and exposed paddle should be C5 - C9 10 nF Capacitor, 0402 Pkg. connected directly to the ground plane similar C10 4.7 µF Tantalum Capacitor, CASE A Pkg. to that shown. A sufficient number of via holes R2 10 Ohm Resistor, 0402 Pkg. should be used to connect the top and bottom R3 1k Ohm Resistor, 0402 Pkg. ground planes. The evaluation circuit board R5, R7 49.9 Ohm Resistor, 0402 Pkg. shown is available from Hittite upon request. R8 0 Ohm Resistor, 0402 Pkg. U1 HMC813LC4B SDLVA [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 or Arlon 25 FR I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
10
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
