Datasheet HMC813 (Analog Devices) - 5
DescriptionSUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 26 GHz
Pages / Page10 / 5 — HMC813. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH LIMITED RF …
File Format / SizePDF / 698 Kb
HMC813. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH LIMITED RF OUTPUT, 1 - 26 GHz. Absolute Maximum Ratings
HMC813 SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 26 GHz Absolute Maximum Ratings
HMC813
v02.0913
SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 26 GHz Absolute Maximum Ratings Die Packaging Information
[1] Vcc1, Vcc2, Vcc3, Vcc4 +3.6V Standard Alternate IP ENBL +3.6V WP-3 (Waffle Pack) [2] H RF Input Power +15 dBm [1] Refer to the “Packaging Information” section for die Channel Temperature 125 °C packaging dimensions. C Continuous Pdiss (T=85°C) [2] For alternate packaging information contact Hittite - 0.51 W Derate 12.63 mW/°C above 85°C Microwave Corporation. Thermal Resistance 79.20 °C/W NOTES: RS (Channel to die bottom) 1. ALL DIMENSIONS IN INCHES [MILLIMETERS] Storage Temperature -65 to +150 °C O 2. DIE THICKNESS IS 0.011 [0.28] 3. TYPICAL BOND PAD IS 0.0024 SQUARE T Operating Temperature -55 to +85 °C 4. BOND PAD METALLIZATION: ALUMINUM C ESD Sensitivity (HBM) Class 1A 5. NO BACKSIDE METAL 6. NO CONNECTION REQUIRED FOR UNLABELED BOND PADS 7. OVERALL DIE SIZE IS ±.002 TE E ELECTROSTATIC SENSITIVE DEVICE D OBSERVE HANDLING PRECAUTIONS R
Outline Drawing
WE O P I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p o plic ra a tio pp n S s u @ p h por ittti : Pte ho.c n om e: 1-800-ANALOG-D
