Datasheet ADL5504 (Analog Devices) - 10
Description450 MHz TO 6000 MHz TruPwr™ Detector
Pages / Page26 / 10 — ADL5504. TYPICAL PERFORMANCE CHARACTERISTICS. (V). d R (. T U O. RRO E. …
ADL5504. TYPICAL PERFORMANCE CHARACTERISTICS. (V). d R (. T U O. RRO E. 0.1. 450. 900. 1900. 2600. 3500. 5000. 6000. 0.01. –25. –20. –15. –10. INPUT (dBm). 2.0
ADL5504 TYPICAL PERFORMANCE CHARACTERISTICS (V) d R ( T U O RRO E 0.1 450 900 1900 2600 3500 5000 6000 0.01 –25 –20 –15 –10 INPUT (dBm) 2.0
TA = 25°C, VS = 3.0 V, CFLTR = 10 nF, COUT = open, light condition ≤ 600 lux, 75 Ω input termination resistor; colors: black = +25°C, blue = −40°C, red = +85°C; unless otherwise noted.
10 3 2 1 1 (V) B) T d R ( PU 0 T U O RRO E 0.1 –1 450 450 900 900 1900 1900 2600 –2 2600 3500 3500 5000 5000 6000 6000 0.01 –3 –25 –20 –15 –10 –5 0 5 10 15
004
007
INPUT (dBm)
08437-
INPUT (dBm)
08437- Figure 4. Output vs. Input Level, 450 MHz, 900 MHz, 1900 MHz, 2600 MHz, Figure 7. Linearity Error vs. Input Level, 450 MHz, 900 MHz, 1900 MHz, 3500 MHz, 5000 MHz, 6000 MHz Frequencies, 3.0 V Supply 2600 MHz, 3500 MHz, 5000 MHz, 6000 MHz Frequencies, 3.0 V Supply
2.0 10 450 1.8 900 1900 2600 1.6 3500 5000 1.4 6000 1 1.2 (V) T (V) T 1.0 PU T PU T U 0.8 U O O 0.6 0.1 0.4 2.5V 2.7V 0.2 3.0V 3.3V 0 0.01 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0
005
008
INPUT (V rms) INPUT (dBm)
08437- 08437- Figure 5. Output vs. Input Level (Linear Scale), 450 MHz, 900 MHz, 1900 MHz, Figure 8. Output vs. Input Level, 900 MHz Frequency, 2600 MHz, 3500 MHz, 5000 MHz, 6000 MHz Frequencies, 3.0 V Supply 2.5 V, 2.7 V, 3.0 V, and 3.3 V Supplies
2.5 100 700 1.4 600 1.2 2.0 80 ) rms) ) F Ω 500 1.0 /V p ( V V) ( 1.5 60 N ( (m ACE AI ANCE 400 SHUNT CAPACITANCE 0.8 T T EPT N G C IS ACI S IO 1.0 40 ER 300 0.6 RE RS T CAP E IN NV HUNT 200 SHUNT RESISTANCE 0.4 HUNT S CO S 0.5 20 100 0.2 0 0 0 1k 2k 3k 4k 5k 6k 0 0
006
0.5 1.0 1.5 2.0 2.5 3.0
009
FREQUENCY (MHz)
08437-
FREQUENCY (GHz)
08437- Figure 6. Conversion Gain and Intercept vs. Frequency, 3.0 V Supply Figure 9. Input Impedance vs. Frequency, 3.0 V Supply, at −40°C, +25°C, and +85°C at −40°C, +25°C, and +85°C Rev. A | Page 8 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description RMS Circuit Description and Filtering Filtering Output Buffer Applications Information Basic Connections RF Input Interfacing Resistive Tap RF Input Multiple RF Inputs Linearity Output Swing Output Offset Output Drive Capability and Buffering Selecting the Square-Domain Filter and Output Low-Pass Filter Power Consumption, Enable, and Power-On/Power-Off Response Time Device Calibration and Error Calculation Calibration for Improved Accuracy Drift over a Reduced Temperature Range Device Handling Evaluation Board Land Pattern and Soldering Information Outline Dimensions Ordering Guide
