Datasheet HMC713LP3E (Analog Devices) - 5
Description54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz
Pages / Page12 / 5 — HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. …
File Format / SizePDF / 918 Kb
HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. OUTP Slope vs. Frequency. OUTP Slope vs. Supply Voltage
HMC713LP3E 54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz OUTP Slope vs Frequency OUTP Slope vs Supply Voltage
HMC713LP3E
v01.1009
54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz OUTP Slope vs. Frequency OUTP Slope vs. Supply Voltage
27 27 25 25 0.05GHz 0.1GHz +25C 0.5GHz +85C 0.9GHz 23 -40C 23 1.9GHz 2.7GHz 5.8GHz (mV/dB) 3.9GHz 21 (mV/dB) 21 7GHz 8GHz SLOPE 19 19 SLOPE 11 17 17 15 15 0 1 2 3 4 5 6 7 8 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 FREQUENCY (GHz) VOLTAGE SUPPLY (V) t M s
OUTP Intercept vs. Frequency OUTP Intercept vs. Supply Voltage
s - -40 -40 r 0.05GHz -50 0.1GHz o ) -50 0.5GHz ) 0.9GHz t m m 1.9GHz (dB -60 2.7GHz c T (dB 3.9GHz T P P -60 5.8GHz e E E C 7GHz C R 8GHz R t -70 E T E T e IN IN -70 -80 +25C +85C -40C r D -90 -80 e 0 1 2 3 4 5 6 7 8 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 FREQUENCY (GHz) VOLTAGE SUPPLY (V) w o P
OUTP vs. Frequency & Input Power OUTP Voltage & Error vs. Frequency
1.4 0.05GHz 2.7GHz 1.8 6 0.1GHz 3.9GHz 0dBm 0.5GHz 5.8GHz 1.2 0.9GHz 7GHz -10dBm 1.5 1.9GHz 8GHz 4 1 ERROR ) -20dBm 1.2 2 E 0.8 (V ) R P -30dBm T (V R U P 0.9 0 O 0.6 T R O -40dBm U ( O dB 0.4 0.6 -2 ) -50dBm OUTP 0.2 -60dBm 0.3 -4 0 0 -6 0 1 2 3 4 5 6 7 8 FREQUENCY (GHz) -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
11 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
