Datasheet ADL5501 (Analog Devices) - 5
Description50 MHz TO 6 GHz TruPwr™ Detector
Pages / Page30 / 5 — ADL5501. SPECIFICATIONS. Table 1. Parameter Condition. Min. Typ. Max. Unit
RevisionB
ADL5501 SPECIFICATIONS Table 1 Parameter Condition Min Typ Max Unit
link to page 30 link to page 30 link to page 10 link to page 10 link to page 10 link to page 30 link to page 10 link to page 30 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10
TA = 25°C, VS = 3.0 V, CFLTR = open, COUT = 100 nF, unless otherwise specified.
Table 1. Parameter Condition Min Typ Max Unit
FREQUENCY RANGE Input RFIN 50 6000 MHz RMS CONVERSION (f = 50 MHz) Input RFIN to Output VRMS Input Impedance 87||6.9 Ω||pF Input Return Loss 11.0 dB Dynamic Range1 CW input, −40°C < TA < +85°C ±1 dB Error2 VS = 3 V 25 dB VS = 5 V 26 dB ±2 dB Error2 VS = 3 V 32 dB VS = 5 V 35 dB Maximum Input Level ±1 dB error2 8 dBm Minimum Input Level ±1 dB error2 −18 dBm Conversion Gain VOUT = (gain × VIN) + intercept 4.5 V/V rms Output Intercept3 0.03 V Output Voltage—High Power In PIN = 5 dBm, 400 mV rms 1.81 V Output Voltage—Low Power In PIN = −21 dBm, 20 mV rms 0.11 V Temperature Sensitivity PIN = −5 dBm 25°C ≤ TA ≤ 85°C 0.0039 dB/°C −40°C ≤ TA ≤ +25°C −0.0037 dB/°C RMS CONVERSION (f = 100 MHz) Input RFIN to Output VRMS Input Impedance 78||4.2 Ω||pF Input Return Loss 12.6 dB Dynamic Range1 CW input, −40°C < TA < +85°C ±0.25 dB Error4 Delta from 25°C, VS = 5 V 28 dB ±0.25 dB Error2 VS = 3 V 19 dB VS = 5 V 20 dB ±1 dB Error2 VS = 3 V 23 dB VS = 5 V 27 dB ±2 dB Error2 VS = 3 V 26 dB VS = 5 V 30 dB Maximum Input Level ±1 dB error2 6 dBm Minimum Input Level ±1 dB error2 −18 dBm Conversion Gain VOUT = (gain × VIN) + intercept 6.1 V/V rms VS = 5 V 5.6 7.8 V/V rms Output Intercept3 0.03 V VS = 5 V −0.02 +0.1 V Output Voltage—High Power In PIN = 5 dBm, 400 mV rms 2.47 V Output Voltage—Low Power In PIN = −21 dBm, 20 mV rms 0.13 V Temperature Sensitivity PIN = −5 dBm 25°C ≤ TA ≤ 85°C 0.0028 dB/°C −40°C ≤ TA ≤ +25°C −0.0018 dB/°C Rev. B | Page 3 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION FILTERING APPLICATIONS INFORMATION BASIC CONNECTIONS OUTPUT SWING LINEARITY INPUT COUPLING USING A SERIES RESISTOR MULTIPLE RF INPUTS SELECTING THE SQUARE-DOMAIN FILTER AND OUTPUT LOW-PASS FILTER POWER CONSUMPTION, ENABLE, AND POWER-ON/POWER-OFF RESPONSE TIME OUTPUT DRIVE CAPABILITY AND BUFFERING VRMS OUTPUT OFFSET DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
