Datasheet HMC601LP4, 601LP4E (Analog Devices) - 9
Description75dB Logarithmic Detector/Controller SMT, 10 - 4000 MHz
Pages / Page10 / 9 — HMC601LP4 / 601LP4E. 75 dB, FAST SETTLING, LOGARITHMIC. DETECTOR / …
File Format / SizePDF / 559 Kb
HMC601LP4 / 601LP4E. 75 dB, FAST SETTLING, LOGARITHMIC. DETECTOR / CONTROLLER 10 - 4000 MHz. Evaluation PCB
HMC601LP4 / 601LP4E 75 dB, FAST SETTLING, LOGARITHMIC DETECTOR / CONTROLLER 10 - 4000 MHz Evaluation PCB
HMC601LP4 / 601LP4E
v01.0509
12 T S - SM R O T C E T E R D E W O P
List of Materials for Evaluation PCB 115242 [1]
The circuit board used in the fi nal application should Item Description use RF circuit design techniques. Signal lines J1 - J4 PC Mount SMA Connector should have 50 ohm impedance while the package J5 - J8 DC Pin ground leads and exposed paddle should be con- C1, C2 1000 pF Capacitor, 0402 Pkg. nected directly to the ground plane similar to that C3, C4 0.1μF Capacitor, 0402 Pkg. shown. A sufficient number of via holes should be R1, R2 5.6Ω Resistor, 0603 Pkg. used to connect the top and bottom ground planes. R3-R5 0Ω Resistor, 0603 Pkg. The evaluation circuit board shown is available from HMC601LP4 / HMC601LP4E U1 Hittite upon request. Logarithmic Detector / Controller PCB [2] 115244 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373
12 - 16
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
