20 /10 — Data Sheet. AD8319. j0.5. 10k. j0.2. z) H / V n (. –60dBm. 0.2. 0.5. NS …
Revision
D
PDF / 1.1 Mb
Data Sheet. AD8319. j0.5. 10k. j0.2. z) H / V n (. –60dBm. 0.2. 0.5. NS DE. RF OFF. 100MHz. –20dBm. –10dBm. –j0.2. –40dBm. 900MHz. E 100. P S E. 1900MHz. 0dBm
Data SheetAD8319j1j0.5j210kj0.2z) H / V n (–60dBmY1kIT00.20.512NS DERF OFF100MHzAL–20dBmR–10dBm–j0.2CT–40dBm900MHzE 100P S E1900MHzIS0dBm2200MHzNO 8 8000MHz–j0.5–j2 01 5- 3600MHz 70 05 10START FREQUENCY = 0.05GHz–j11k10k100k1M10M 5 STOP FREQUENCY = 10GHz -01 FREQUENCY (Hz)10000MHz5800MHz 705 05 Figure 15. Input Impedance vs. Frequency; No Termination Resistor on INHI Figure 18. Noise Spectral Density of Output vs. Frequency; CLPF = Open (Impedance De-Embedded to Input Pins), Z0 = 50 Ω ∆ : 1.53V10k@ : 1.53V)/ Hz V n ( Y1kIT NS DERAL CT E 100P1S E IS NO 9 -016 01 5- 705 70 05 05 10Ch1 500mVM2.00µsA CH1 420V1k10k100k1M10MT 29.60%FREQUENCY (Hz) Figure 16. Power On/Off Response Time; VP = 3.0 V; Figure 19. Noise Spectral Density of Output Buffer vs. Frequency (from CLPF Input AC-Coupling Capacitors = 10 pF; CLPF = Open to VOUT); CLPF = 0.1 μF 2.002.0CH1 RISE3.3V9.949ns1.751.53.0VCH1 FALL6.032ns1.503.6V1.01.250.5))B d(V T 1.00R (0OUVRO R0.75E–0.50.50–1.00.25–1.5 17 -0 705 10–2.0 05 –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –50510 20 0 Ch1 200mVM20.0nsA CH1 1.04V 5- 70 T 72.40%PIN (dBm) 05 Figure 17. V Figure 20. V OUT Pulse Response Time; Pulsed RF Input 0.1 GHz, −10 dBm; OUT Stability and Error vs. Supply Voltage at 1.9 GHz C When V LPF = Open; RLOAD = 150 Ω POS Varies by 10% Rev. D | Page 9 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8319 BASIC CONNECTIONS INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE MEASUREMENT MODE SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE CONTROLLER MODE OUTPUT FILTERING OPERATION BEYOND 8 GHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
