Datasheet ADL5500 (Analog Devices) - 2
Description100 MHz TO 6 GHz TruPwr™ Detector
Pages / Page26 / 2 — ADL5500* PRODUCT PAGE QUICK LINKS Last Content Update: 10/03/2017. …
ADL5500* PRODUCT PAGE QUICK LINKS Last Content Update: 10/03/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADL5500* PRODUCT PAGE QUICK LINKS Last Content Update: 10/03/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADL5500 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADL5500 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all ADL5500 EngineerZone Discussions. • AN-1040: RF Power Calibration Improves Performance of Wireless Transmitters
SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • ADL5500: 100 MHz to 6 GHz TruPwr™ Detector Data Sheet
TECHNICAL SUPPORT TOOLS AND SIMULATIONS
Submit a technical question or find your regional support • ADIsimPLL™ number. • ADIsimRF • ADL5500 S-Parameters
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
REFERENCE MATERIALS Product Selection Guide
• RF Source Booklet
Technical Articles
• Log Amps and Directional Couplers Enable VSWR Detection • Measuring the RF Power in CDMA2000 and W-CDMA High Power Amplifiers (HPAs)
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION FILTERING APPLICATIONS INFORMATION BASIC CONNECTIONS OUTPUT SWING LINEARITY INPUT COUPLING USING A SERIES RESISTOR MULTIPLE RF INPUTS SELECTING THE OUTPUT LOW-PASS FILTER NETWORK POWER CONSUMPTION AND POWER-ON/-OFF RESPONSE OUTPUT DRIVE CAPABILITY AND BUFFERING VRMS OUTPUT OFFSET DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION ABOVE 4.0 GHz DEVICE HANDLING EVALUATION BOARD Land Pattern and Soldering Information Junction-to-Board Thermal Impedance OUTLINE DIMENSIONS ORDERING GUIDE
