Datasheet AD8312 (Analog Devices) - 6
Description50 MHz TO 3.5 GHz, 45 dB RF Detector
Pages / Page21 / 6 — Data Sheet. AD8312. Parameter. Test Conditions/Comments. Min. Typ. Max. …
RevisionB
Data Sheet. AD8312. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8312 Parameter Test Conditions/Comments Min Typ Max Unit
POWER INTERFACE VPOS (Pin 1) Supply Voltage 2.7 3.0 5.5 V Quiescent Current 2.8 4.2 5.7 mA vs. Temperature −40°C ≤ TA ≤ +85°C 4.3 mA 1 Increased output is possible when using an attenuator between VOUT and VSET to raise the slope. Rev. B | Page 5 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS GENERAL DESCRIPTION APPLICATIONS INFORMATION BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT Filter Capacitor Input Coupling Options Increasing the Logarithmic Slope Effect of Waveform Type on Intercept Temperature Drift Operation Above 2.5 GHz Device Handling Evaluation Board OUTLINE DIMENSIONS ORDERING GUIDE
