Datasheet AD8318 (Analog Devices) - 2
Description1 MHz TO 8 GHz, 70 dB Logarithmic Detector/Controller
Pages / Page25 / 2 — AD8318* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionD
AD8318* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8318* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• RF Source Booklet
EVALUATION KITS Technical Articles
• AD8318 Evaluation Board • Design a Logamp RF Pulse Detector • Detecting Fast RF Bursts using Log Amps
DOCUMENTATION
• Log Amps and Directional Couplers Enable VSWR
Application Notes
Detection • AN-1040: RF Power Calibration Improves Performance of • Make Precise Base-Station Power Measurements Wireless Transmitters • Measurement and Control of RF Power, Part I
Data Sheet
• Measurement and Control of RF Power, Part II • AD8318-DSCC: Military Data Sheet • Measurement and Control of RF Power, Part III • AD8318-EP: Enhanced Product Data Sheet • Measuring the RF Power in CDMA2000 and W-CDMA High • AD8318: 1 MHz to 8 GHz, 70 dB Logarithmic Detector/ Power Amplifiers (HPAs) Controller Data Sheet • Measuring VSWR and Gain in Wireless Systems
SOFTWARE AND SYSTEMS REQUIREMENTS DESIGN RESOURCES
• BeMicro FPGA Project for CN0150 with Nios driver • AD8318 Material Declaration • CN0150 FMC-SDP Interposer & Evaluation Board / Xilinx • PCN-PDN Information KC705 Reference Design • Quality And Reliability
TOOLS AND SIMULATIONS
• Symbols and Footprints • ADIsimPLL™
DISCUSSIONS
• ADIsimRF View all AD8318 EngineerZone Discussions.
REFERENCE DESIGNS SAMPLE AND BUY
• CN0050 Visit the product page to see pricing options. • CN0150
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION USING THE AD8318 BASIC CONNECTIONS ENABLE INTERFACE INPUT SIGNAL COUPLING OUTPUT INTERFACE SETPOINT INTERFACE TEMPERATURE COMPENSATION OF OUTPUT VOLTAGE TEMPERATURE SENSOR MEASUREMENT MODE DEVICE CALIBRATION AND ERROR CALCULATION SELECTING CALIBRATION POINTS TO IMPROVE ACCURACY OVER A REDUCED RANGE VARIATION IN TEMPERATURE DRIFT FROM DEVICE TO DEVICE TEMPERATURE DRIFT AT DIFFERENT TEMPERATURES SETTING THE OUTPUT SLOPE IN MEASUREMENT MODE RESPONSE TIME CAPABILITY OUTPUT FILTERING CONTROLLER MODE CHARACTERIZATION SETUP AND METHODS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
