Datasheet AD8318-EP (Analog Devices) - 4
Description1 MHz TO 8 GHz, 70 dB Logarithmic Detector/Controller
Pages / Page12 / 4 — AD8318-EP. Enhanced Product. Parameter. Test Conditions/Comments. Min. …
File Format / SizePDF / 439 Kb
AD8318-EP. Enhanced Product. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD8318-EP Enhanced Product Parameter Test Conditions/Comments Min Typ Max Unit
link to page 5 link to page 5
f = 3.6 GHz R = 51 Ω TADJ Input Impedance 119||0.7 Ω||pF ±3 dB Dynamic Range T = 25°C 70 dB A −55°C < T < +105°C 61 dB A ±1 dB Dynamic Range T = 25°C 58 dB A Maximum Input Level ±1 dB error −2 dBm Minimum Input Level ±1 dB error –60 dBm Slope −24.3 mV/dB Intercept 19.8 dBm Output Voltage—High Power In P = −10 dBm 0.717 V IN Output Voltage—Low Power In P = −40 dBm 1.46 V IN Temperature Sensitivity P = −10 dBm IN 25°C ≤ T ≤ 105°C 0.0012 dB/°C A −55°C ≤ T ≤ +25°C 0.009 dB/°C A f = 5.8 GHz R = 1000 Ω TADJ Input Impedance 33||0.59 Ω||pF ±3 dB Dynamic Range T = 25°C 70 dB A −55°C < T < +105°C 62 dB A ±1 dB Dynamic Range T = 25°C 57 dB A Maximum Input Level ±1 dB error −1 dBm Minimum Input Level ±1 dB error −58 dBm Slope −24.3 mV/dB Intercept 25 dBm Output Voltage—High Power In P = −10 dBm 0.86 V IN Output Voltage—Low Power In P = −40 dBm 1.59 V IN Temperature Sensitivity P = −10 dBm IN 25°C ≤ T ≤ 105°C 0.019 dB/°C A −55°C ≤ T ≤ +25°C 0.0096 dB/°C A f = 8.0 GHz R = 500 Ω TADJ ±3 dB Dynamic Range T = 25°C 60 dB A −55°C < T < +105°C 58 dB A Maximum Input Level ±3 dB error 3 dBm Minimum Input Level ±3 dB error −55 dBm Slope −23 mV/dB Intercept 37 dBm Output Voltage—High Power In P = −10 dBm 1.06 V IN Output Voltage—Low Power In P = −40 dBm 1.78 V IN Temperature Sensitivity P = −10 dBm IN 25°C ≤ T ≤ 105°C 0.032 dB/°C A −55°C ≤ T ≤ +25°C 0.0078 dB/°C A OUTPUT INTERFACE VOUT (Pin 6) Voltage Swing V = 0 V; P = −10 dBm, no load1 4.9 V SET IN V = 2.1 V; P = −10 dBm, no load1 25 mV SET IN Output Current Drive V = 1.5 V; P = −50 dBm 60 mA SET IN Small Signal Bandwidth P = −10 dBm; from CLPF to VOUT 60 MHz IN Video Bandwidth (or Envelope Bandwidth) 45 MHz Output Noise P = 2.2 GHz; −10 dBm, f = 100 kHz, C = 220 pF 90 nV/√Hz IN NOISE LPF Fall Time P = Off to −10 dBm, 90% to 10% 10 ns IN Rise Time P = −10 dBm to off, 10% to 90% 12 ns IN Rev. 0 | Page 4 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Outline Dimensions Ordering Guide
