Datasheet AD8361 (Analog Devices) - 8
DescriptionLF to 2.5 GHz TruPwr™ Detector
Pages / Page23 / 8 — Data Sheet. AD8361. 3.0. 2.5. 2.0. 1.5. +85°C. 1.0. 0.5. RROR (dB) –0.5. …
RevisionF
File Format / SizePDF / 611 Kb
Data Sheet. AD8361. 3.0. 2.5. 2.0. 1.5. +85°C. 1.0. 0.5. RROR (dB) –0.5. –1.0. MEAN. 3 SIGMA. –40°C. –1.5. –2.0. –2.5. –3.0. 0.01. 0.02. 0.1. 0.4. (–21dBm). (–7dBm)
Data Sheet AD8361 3.0 2.5 2.0 1.5 +85°C 1.0 0.5 RROR (dB) –0.5 –1.0 MEAN 3 SIGMA –40°C –1.5 –2.0 –2.5 –3.0 0.01 0.02 0.1 0.4 (–21dBm) (–7dBm)
link to page 13
Data Sheet AD8361 3.0 3.0 2.5 2.5 2.0 2.0 1.5 1.5 +85°C 1.0 1.0 0.5 0.5 0 0 RROR (dB) –0.5 RROR (dB) –0.5 E E –1.0 –1.0 MEAN
3 SIGMA –40°C –1.5 –1.5 –2.0 –2.0 2.5 –2.5 –3.0 –3.0 0.01 0.02 0.1 0.4 0.01 0.02 0.1 0.4 (–21dBm) (–7dBm) (+5dBm) (–21dBm) (–7dBm) (+5dBm) INPUT (V rms)
01088-C-012
INPUT (V rms)
01088-C-015 Figure 12. Error from CW Linear Reference vs. Input, 3 Sigma to Either Side of Figure 15. Output Delta from +25°C vs. Input Level, 3 Sigma to Either Mean, IS95 Reverse Link Signal, Supply 3.0 V, Frequency 900 MHz Side of Mean Sine Wave, Supply 3.0 V, Frequency 1900 MHz, Temperature −40°C to +85°C
3.0 11 2.5 V 10 S = 5V INPUT OUT 2.0 9 OF RANGE 1.5 8 –40°C +25°C 1.0 7 VS = 3V 0.5 NT (mA) INPUT OUT 6 OF RANGE 0 +85°C 5 CURRE RROR (dB) –0.5 Y +25°C E L 4 P –1.0 P MEAN
3 SIGMA U +85°C S 3 –1.5 –2.0 2 –2.5 1 –40°C –3.0 0 0.01 0.02 0.1 0.6 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 (–21dBm) (–7dBm) (+8.6dBm) INPUT (V rms)
01088-C-016
INPUT (V rms)
01088-C-013 Figure 13. Error from CW Linear Reference vs. Input Level, 3 Sigma to Either Figure 16. Supply Current vs. Input Level, Supplies 3.0 V, and 5.0 V, Side of Mean, IS95 Reverse Link Signal, Supply 5.0 V, Frequency 900 MHz Temperatures −40°C, +25°C, and +85°C
3.0 250 1.8 +25°C 2.5 +85°C 1.6 2.0 200 1.5 ) +85°C –40°C 1.4 ( (pF) 1.0 +85°C 0.5 150 1.2 TANCE 0 IS S ACITANCE 1.0 RROR (dB) –0.5 E 100 –1.0 +25°C –40°C HUNT RE 0.8 –1.5 S HUNT CAP –40°C S 50 –2.0 0.6 –2.5 –3.0 0 0.4 0.01 0.02 0.1 0.4 0 500 1000 1500 2000 2500 (–21dBm) (–7dBm) (+5dBm) FREQUENCY (MHz)
01088-C-017
INPUT (V rms)
01088-C-014 Figure 14. Output Delta from +25°C vs. Input Level, 3 Sigma to Figure 17. Input Impedance vs. Frequency, Supply 3 V, Either Side of Mean Sine Wave, Supply 3.0 V, Temperatures −40°C, +25°C, and +85°C, MSOP Frequency 900 MHz, Temperature −40°C to +85°C (See the Application Information Section for SOT-23 Data) Rev. F | Page 7 of 22 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION Filtering Offset APPLICATION INFORMATION Basic Connections Output Swing Dynamic Range Input Coupling and Matching Input Coupling Using a Series Resistor Selecting the Filter Capacitor Operation at Low Frequencies Power Consumption, Enable and Power-On Volts to dBm Conversion Output Drive Capability and Buffering OUTPUT REFERENCE TEMPERATURE DRIFT COMPENSATION Extended Frequency Characterization EVALUATION BOARD CHARACTERIZATION SETUPS Equipment Analysis OUTLINE DIMENSIONS ORDERING GUIDE
