Datasheet AD8306 (Analog Devices) - 6
Description5 MHz TO 400 MHz, 100 dB High Precision Limiting - Logarithmic Amplifier
Pages / Page25 / 6 — STANDARD. 5962-98646. MICROCIRCUIT DRAWING
File Format / SizePDF / 412 Kb
STANDARD 5962-98646 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics. Conditions 1/ 2/ Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits Unit V subgroups type PS1/VPS2 = ENBL = +5 V, P IN single ended input, Min Max unless otherwise specified Quiescent current IS Zero-signal, LMDR open, 1 01 13 20 mA ENBL > 3 V 2,3 10 24 PIN = 0 V, RLIM = open, 1 02,03 13 20 ENBL = VPS, 2,3 10 24 VPS = 2.7 V, 5 V, 6.5 V M, D, P, L, R 1 02 13 20 M, D, P, L 03 13 20 Zero-signal, LMDR open, Disable current IDIS 1,2,3 01 -25 25 µA ENBL < 0.5 V PIN = 0 V, RLIM = open, ENBL = 0 V, 02,03 -25 25 VPS = 2.7 V, 5 V, 6.5 V M, D, P, L, R 1 02 -25 25 M,D,P,L 03 -25 25 Additional I 1,2,3 02,03 8 22.5 mA S current 3/ ILIM10 PIN = 0V, ENBL = VPS, from 10 mA limiter R output drive current LOAD= 100 Ω, f = 5 MHz, RLIM = 40 Ω (IOUT = 10 mA), VPS = 2.7 V, 5 V, 6.5 V M, D, P, L, R 1 02 8 22.5 M,D,P,L 03 8 22.5 Additional I 1,2,3 02,03 1.5 2.25 mA S current 3/ ILIM1 PIN = 0V, ENBL = VPS, from 1 mA limiter R output drive current LOAD = 100 Ω, f = 5 MHz, RLIM = 400 Ω (IOUT = 1 mA), VPS = 2.7 V, 5 V, 6.5 V M, D, P, L, R 1 02 1.5 2.25 M,D,P,L 03 1.5 2.25 ENBL input high logic VIH VPS = 2.7 V, 5 V, 6.5 V 1,2,3 02,03 2.7 VS V level voltage M, D, P, L, R 1 02 2.7 VS M, D, P, L 03 2.7 VS See footnotes at end of table.
STANDARD
SIZE
5962-98646 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 D 6 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
