Datasheet AD8306 (Analog Devices) - 9
Description5 MHz TO 400 MHz, 100 dB High Precision Limiting - Logarithmic Amplifier
Pages / Page25 / 9 — STANDARD. 5962-98646. MICROCIRCUIT DRAWING
File Format / SizePDF / 412 Kb
STANDARD 5962-98646 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics - Continued. Conditions 1/ 2/ Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits Unit V subgroups type PS1/VPS2 = ENBL = +5 V unless otherwise specified Min Max Limiting amplifier LMHI and LIMLO section - continued. Usable input signal 4/ 5/ P 4,5,6 02,03 -78 +9 dBV IN LIM Differential INHI to INLO input range for limiter level for limiter, VPS = 5 V, 6.5 V Differential INHI to INLO input -78 +3 level for limiter, VPS = 2.7 V Logarithmic amplifier section. Transfer slope VYAC f = 10 MHz, 4 01 19.4 20.6 mV/dB -40 dBm < PIN < 0 dBm 5,6 19.25 20.75 f = 5 MHz, 4 02,03 19.7 20.9 -63 dBV < PIN < -23 dBV 5,6 19.55 21.05 M, D, P, L, R 4 02 19.7 20.9 M, D, P, L 03 19.7 20.9 f = 100 MHz, 4 02,03 19.4 20.6 -63 dBm < PIN < -23 dBm 5,6 19.25 20.75 M, D, P, L, R 4 02 19.4 20.6 M, D, P, L 03 19.4 20.6 Transfer slope VYAC f = 400 MHz, 6/ 4,5,6 02,03 18.5 19.2 mV/dB -63 dBm < PIN < -23 dBm Intercept VXAC f = 10 MHz 4 01 -110.4 -105.6 dBV 5,6 -111.0 -105.0 f = 5 MHz 4 02,03 -110.4 -105.6 5,6 -111.0 -105.0 M, D, P, L, R 4 02 -110.4 -105.6 M, D, P, L 03 -110.4 -105.6 f = 100 MHz 4 02,03 -108.4 -103.6 5,6 -109.0 -103.0 M, D, P, L, R 4 02 -108.4 -103.6 M, D, P, L 03 -108.4 -103.6 f = 400 MHz 6/ 4,5,6 02,03 -112 -107.4 See footnotes at end of table.
STANDARD
SIZE
5962-98646 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 D 9 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
