Datasheet AD641 (Analog Devices) - 4
Description250 MHz Demodulating Logarithmic Amplifier
Pages / Page18 / 4 — AD641. ABSOLUTE MAXIMUM RATINGS*. THERMAL CHARACTERISTICS. C/W). CAUTION. …
RevisionD
File Format / SizePDF / 426 Kb
AD641. ABSOLUTE MAXIMUM RATINGS*. THERMAL CHARACTERISTICS. C/W). CAUTION. WARNING!. ESD SENSITIVE DEVICE. Revision History
AD641 ABSOLUTE MAXIMUM RATINGS* THERMAL CHARACTERISTICS C/W) CAUTION WARNING! ESD SENSITIVE DEVICE Revision History
Supply Voltages . ± 7.5 V ␪ ␪ Input Voltage (Pin 1 or Pin 20 to COM) . –3 V to +300 mV
JC JA (
C/W) (
C/W)
Attenuator Input Voltage (Pin 5 to Pin 3/4) . ± 4 V Storage Temperature Range, Q . –65°C to +150°C 20-Lead Plastic DIP Package (N) 24 61 Storage Temperature Range, N, P . –65°C to +125°C 20-Lead Cerdip Package (Q) 25 85 Ambient Temperature Range, Rated Performance 20-Lead Plastic Leadless Chip Carrier (P) 28 75 Industrial, AD641A . –40°C to +85°C Military, AD641S . –55°C to +125°C Lead Temperature Range (Soldering 60 sec) . +300°C *Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may adversely affect device reliability.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily
WARNING!
accumulate on the human body and test equipment and can discharge without detection. Although the AD641 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD
precautions are recommended to avoid performance degradation or loss of functionality.
Revision History 6/2016--Rev. C to Rev. D
Changes to Log Amplifier Performance, Slope Current, IY Over Temperature Parameter (AD641S Only)...2 Changes to Log Amplifier Performance, Intercept dBm Parameter...2 Changes to Log Amplifier Performance, Intercept dBm, Over Temperature Parameter..2 Added Revision History Section ..3 Updated Outline Dimensions..16 Moved Ordering Guide...16 REV. D –3– Document Outline FEATURES PRODUCT DESCRIPTION PIN CONFIGURATIONS AD641--SPECIFICATIONS ELECTRICAL CHARACTERISTICS THERMAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION REVISION HISTORY AD641--TYPICAL DC PERFORMANCE CHARACTERISTICS TYPICAL AC PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION CIRCUIT OPERATION FUNDAMENTALS OF LOGARITHMIC CONVERSION INTERCEPT STABILIZATION CONVERSION RANGE EFFECT OF WAVEFORM ON INTERCEPT LOGARITHMIC CONFORMANCE AND WAVEFORM SIGNAL MAGNITUDE INTERCEPT AND LOGARITHMIC OFFSET OPERATION OF A SINGLE AD641 ACTIVE CURENT-TO-VOLTAGE CONVERSION EFFECT OF FREQUENCY ON CALIBRATION SOURCE RESISTANCE AND INPUT OFFSET USING HIGHER SUPPLY VOLTAGES USING THE ATTENUATOR OPERATION OF CASCADED AD641s ELIMINATING THE EFFECT OF FIRST STAGE OFFSET PRACTICAL APPLICATIONS RSSI APPLICATIONS 250 MHz RSSI CONVERTER WITH 58 dB DYNAMIC RANGE OUTLINE DIMENSIONS ORDERING GUIDE
