Datasheet LTC6905-XXX (Analog Devices) - 2
DescriptionFixed Frequency SOT-23 Oscillator
Pages / Page8 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order …
File Format / SizePDF / 158 Kb
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order Options. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) Order Options ELECTRICAL CHARACTERISTICS The
LTC6905-XXX Series
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
Supply Voltage (V+) to GND ..– 0.3V to 6V TOP VIEW DIV to GND .. – 0.3V to (V+ + 0.3V) V+ 1 5 OUT OE to GND ... – 0.3V to (V+ + 0.3V) GND 2 Output Short-Circuit Duration (Note 6) ... Indefinite OE 3 4 DIV Operating Temperature Range (Note 8) S5 PACKAGE 5-LEAD PLASTIC SOT-23 LTC6905C .. – 40°C to 85°C TJMAX = 125°C, θJA = 150°C/W LTC6905I .. – 40°C to 85°C LTC6905H .. – 40°C to 125°C ORDER PART NUMBER S5 PART MARKING* Specified Temperature Range (Note 8) LTC6905CS5-133 LTBPM LTC6905C ... 0°C to 70°C LTC6905IS5-133 LTBPM LTC6905I .. – 40°C to 85°C LTC6905HS5-133 LTBPM LTC6905H .. – 40°C to 125°C LTC6905CS5-100 LTBPK Storage Temperature Range ... – 65°C to 150°C LTC6905IS5-100 LTBPK Lead Temperature (Soldering, 10 sec).. 300°C LTC6905HS5-100 LTBPK LTC6905CS5-96 LTBPJ LTC6905IS5-96 LTBPJ LTC6905HS5-96 LTBPJ LTC6905CS5-80 LTBPH LTC6905IS5-80 LTBPH LTC6905HS5-80 LTBPH
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ *The temperature grade is identified by a label on the shipping container.
denotes the specifications which apply over the full specified temperature range, otherwise specifications are at TA = 25
C or as noted. OE = DIV = V+, V+ = 2.7V to 3.6V, RL = 15k, CL = 5pF, unless otherwise noted. All voltages are with respect to GND. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
∆f Frequency Accuracy (Notes 2, 7) LTC6905C-XXX TA = 25°C, V+ = 3V ±0.5 ±1.0 % 0°C < TA < 70°C ● ±1.5 % LTC6905I-XXX 25°C < TA < 85°C ±1.8 % – 40°C < TA < 85°C ● ±2.9 % LTC6905H-XXX 25°C < TA < 125°C ±2.3 % – 40°C < TA < 125°C ● ±2.9 % V+ = 5V ±1.5 % ∆f/∆T Freq Drift Over Temp (Note 2) ● ±20 ppm/°C ∆f/∆V Freq Drift Over Supply (Notes 2, 7) V+ = 2.7V to 3.6V 0.5 %/V Timing Jitter (Note 3) 0.8 % Long-Term Stability of Output Frequency 300 ppm/√kHr 6905xfa 2
