Datasheet LTC6909 (Analog Devices) - 2
Description1 to 8 Output, Multiphase Silicon Oscillator with Spread Spectrum Modulation
Pages / Page22 / 2 — Absolute MAxiMuM rAtings. pin conFigurAtion. (Note 1). orDer inForMAtion …
File Format / SizePDF / 315 Kb
Absolute MAxiMuM rAtings. pin conFigurAtion. (Note 1). orDer inForMAtion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
Absolute MAxiMuM rAtings pin conFigurAtion (Note 1) orDer inForMAtion LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC6909
Supply Voltage (V+A) to GND ..6V TOP VIEW Supply Voltage (V+D) to GND ..6V V+A 1 16 SET GND 2 Maximum Voltage 15 PH2 PH0 3 14 MOD on Any Pin .. (GND – 0.3V) ≤ V PH1 4 13 V+D PIN ≤ (V+ + 0.3V) OUT1 5 12 OUT8 Operating Temperature Range (Note 2) OUT2 6 11 OUT7 OUT3 7 10 OUT6 LTC6909C ..–40°C to 85°C OUT4 8 9 OUT5 LTC6909I ...–40°C to 85°C MS PACKAGE 16-LEAD PLASTIC MSOP LTC6909H .. –40°C to 125°C TJMAX = 150°C, θJA = 125°C/W Specified Temperature Range (Note 3) LTC6909C .. 0°C to 70°C LTC6909I ...–40°C to 85°C LTC6909H .. –40°C to 125°C Junction Temperature ... 150°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ...300°C
orDer inForMAtion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6909CMS#PBF LTC6909CMS#TRPBF 6909 16-Lead Plastic MSOP 0°C to 70°C LTC6909IMS#PBF LTC6909IMS#TRPBF 6909 16-Lead Plastic MSOP –40°C to 85°C LTC6909HMS#PBF LTC6909HMS#TRPBF 6909 16-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
electricAl chArActeristics The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C or as noted. Test conditions are V+ = V+A = V+D = 2.7V to 5.5V, RL = 5k, CL = 5pF unless otherwise noted. The modulation is turned off (MOD is connected to OUT1) and PH = 8 unless otherwise specified. RSET is defined as the resistor connected from the SET pin to the V+A pin. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ΔfMASTER Frequency Accuracy (Notes 4, 5) V+ = 5V 500kHz ≤ fMASTER ≤ 10MHz ±1 ±2.5 % PH = 3 500kHz ≤ fMASTER ≤ 10MHz l ±2.5 ±3 % 100kHz ≤ fMASTER < 500kHz l ±3 ±4.5 % 10MHz ≤ fMASTER ≤ 20MHz l ±2.7 ±3.5 % V+ = 2.7V 500kHz ≤ fMASTER ≤ 10MHz ±0.5 ±2.5 % PH = 3 500kHz ≤ fMASTER ≤ 10MHz l ±2 ±3 % 100kHz ≤ fMASTER < 500kHz l ±2.5 ±4.5 % ΔfOUT/ΔT Frequency Drift Over Temperature RSET = 100k l ±0.004 %/°C ΔfOUT/ΔV+ Frequency Drift Over Supply V+ = 4.5V to 5.5V, RSET = 100k l 0.4 0.9 %/V V+ = 2.7V to 3.6V, RSET = 100k l 0.04 0.35 %/V 6909fa 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
