Datasheet LTC1540 (Analog Devices) - 4
DescriptionNanopower Comparator with Reference
Pages / Page14 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 209 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LTC1540
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. V+ = 3V, V– = GND = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Power Supply
V+ Supply Voltage Range l 2 11 V ICC Supply Current IN– – IN + = 80mV, HYST = REF, C-Grade l 0.28 0.61 µA IN– – IN + = 80mV, HYST = REF, I-Grade l 0.64 µA
Comparator
VOS Comparator Input Offset Voltage VCM = 2.5V ±12 mV l ±15 mV LTC1540CMS8/IMS8 l ±16 mV I + – IN Input Leakage Current (IN+, IN–) VIN = VIN = 1.5V l ±0.01 ±1 nA Input Leakage Current (HYST) l ±0.02 ±1 nA VCM Comparator Input Common Mode l V– V+ – 1.3V V Range CMRR Common Mode Rejection Ratio V– to V+ – 1.3V 0.1 1 mV/V PSRR Power Supply Rejection Ratio V+ = 2V to 11V 0.1 1 mV/V VHYST Hysteresis Input Voltage Range l REF – 50mV REF V tPD Propagation Delay COUT = 100pF Overdrive = 10mV 70 µs Overdrive = 100mV 60 µs VOH Output High Voltage IO = –8mA l V+ – 0.4V V VOL Output Low Voltage IO = 0.8mA l GND + 0.4V V
Reference
VREF Reference Voltage No Load (SO-8)/(DFN) Commercial l 1.158 1.182 1.206 V MS8 Commercial l 1.156 1.182 1.208 V (SO-8)/(MS8)/(DFN) Industrial l 1.152 1.182 1.212 V ∆VREF Load Regulation 0 ≤ ISOURCE ≤ 100µA l 0.75 3.5 mV 0 ≤ ISINK ≤ 10µA 0.5 1.5 mV l 5 mV
Note 1:
Note 2:
The θJA specified for the DD package is with minimal PCB heat may cause permanent damage to the device. Exposure to any Absolute spreading metal. Using expanded metal area on all layers of a board Maximum Rating condition for extended periods may affect device reduces this value. reliability and lifetime. 1540fb 4 For more information www.linear.com/LTC1540
