Datasheet AD8634-KGD (Analog Devices)
Description | High Temperature, Low Noise, RRO Dual Operational Amplifier |
Pages / Page | 7 / 1 — High Temperature, Low Power. Operational Amplifier. Known Good Die. … |
File Format / Size | PDF / 189 Kb |
High Temperature, Low Power. Operational Amplifier. Known Good Die. AD8634-KGD. FEATURES. METAL MASK DIE IMAGE
High Temperature, Low Power Operational Amplifier Known Good Die AD8634-KGD FEATURES METAL MASK DIE IMAGE Extreme high temperature operation V+ −40°C to +210°C, tested to +175°C Rail-to-rail output OUT A OUT B Low power: 1.3 mA maximum –IN A –IN B Gain bandwidth product: 9.7 MHz typical at AV = 100 Low offset voltage: 250 μV maximum Unity-gain stable High slew rate: 5.0 V/μs typical at 210°C +IN A +IN B Low noise: 4.2 nV/√Hz typical at 1 kHz and 210°C APPLICATIONS V– Downhole drilling and instrumentation
101
Avionics
1524- 1
Heavy industrial
Figure 1.
High temperature environments GENERAL DESCRIPTION
The AD8634-KGD is a precision, 9.7 MHz bandwidth, dual Additional application and technical information can be found amplifier that features rail-to-rail outputs. The AD8634-KGD is in the AD8634 data sheet. guaranteed to operate from 3 V to 30 V (or from ±1.5 V to The AD8634-KGD is a member of a growing series of high ±15 V) and at very high temperatures. The AD8634-KGD is temperature qualified products offered by Analog Devices, Inc. specified and characterized for −40°C to +210°C and is tested at For a complete selection table of available high temperature +175°C. products, see the high temperature product list and The AD8634-KGD is well suited for applications that require qualification data available at www.analog.com/hightemp. both ac and dc precision performance. The combination of wide bandwidth, low noise, and precision makes the AD8634-KGD useful in a wide variety of applications, including filters and interfacing with a variety of sensors.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Metal Mask Die Image General Description Table of Contents Revision History Specifications Electrical Characteristics, VSY = ±15.0 V Electrical Characteristics, VSY = 5.0 V Absolute Maximum Ratings ESD Caution Pad Configuration And Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
