Datasheet ADA4077-2 (Analog Devices) - 3
Description4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Dual Amplifier
Pages / Page21 / 3 — STANDARD. 5962-14233. MICROCIRCUIT DRAWING
File Format / SizePDF / 350 Kb
STANDARD 5962-14233 MICROCIRCUIT DRAWING
1.3 Absolute maximum ratings. 1/ Supply voltage (+VS to –VS) .. 36 V Input voltage .. ±VSY Input current .. ±10 mA 2/ Differential input voltage .. ±VSY Output short-circuit duration to GND ... Indefinite Storage temperature range .. -65°C to +150°C Maximum junction temperature (TJ) .. +150°C 3/ Lead temperature (soldering, 10 seconds) .. +300°C Thermal resistance, junction-to-case (θJC) .. 33°C/W 4/ Thermal resistance, junction-to-ambient (θJA) ... 52°C/W 4/ 1.4 Recommended operating conditions. Dual Supply voltage (±VS ) ... ±2.5 V to ±15 V Single supply voltage (+VS / 0 V) ... +5.0 V to +30.0 V Ambient operating temperature range (TA) ... -55°C to +125°C 1.4.1 Operating performance characteristics. 5/ VS = ±5.0 V: Common mode input resistance ... 70 GΩ Common mode input capacitance ... 3 pF Unity-Gain Crossover, VIN = 10 mVp-p, RL = 2 kΩ, AV = +1 ... 3.9 MHz Phase margin, VIN = 10 mV p-p, RL = 2 kΩ, AV = +1 .. 85° Total Harmonic Distortion plus noise, VIN = 1 V rms, AV = +1, RL = 2 kΩ, f = 1 kHz ... 0.004% Current noise density .. 0.2 pA/ Hz Multiple amplifiers channel separation, f = 1 kHz, RL = 10 kΩ .. -125 dB VS = ±15.0 V: Common mode input resistance ... 100 GΩ Differential input capacitance .. 3pF Common mode input capacitance ... 5 pF Unity-Gain Crossover, VIN = 10 mVp-p, RL = 2 kΩ, AV = +1 .. 3.9 MHz Settling time to 0.01% VIN = 10 V p-p, RL = 2 kΩ, AV = −1 .. 16 µs Phase margin, VIN = 10 mVPP, RL = 2 kΩ, AV = 1 ... 58° Total harmonic distortion plus noise , VIN = 1 V rms, AV = +1, RL = 2 kΩ, f = 1 ... 0.004% Current noise density .. 0.2 pA/ Hz Multiple amplifiers channel separation, f = 1 kHz, RL = 10 kΩ .. -125 dB ________ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ The input pins have clamp diodes to the power supply pins and to each other. Limit the input current to 10 mA or less Whenever input signals exceed the power supply rail by 0.3 V. 3/ While the device is internally short circuit protected, this may not be sufficient to guarantee that the maximum junction temperature is not exceeded under all conditions. Do not exceed maximum TJ in application with output current load. 4/ Measurement taken under absolute worst case conditions of still air and represents data taken with a thermal camera for highest power density location. See MIL-STD-1835 for average package θJC numbers with smaller die size. 5/ Unless otherwise specified, TA = 25°C, VSY = ±5 V, VSY = ±15 V, and VCM = 0 V.
STANDARD
SIZE
5962-14233 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 A 3 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
