Datasheet ADA4077-2 (Analog Devices) - 6
Description4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Dual Amplifier
Pages / Page21 / 6 — STANDARD. 5962-14233. MICROCIRCUIT DRAWING
File Format / SizePDF / 350 Kb
STANDARD 5962-14233 MICROCIRCUIT DRAWING
TABLE IA. Electrical performance characteristics. Test Symbol Conditions 1/ 2/ Group A Device Limits Unit -55°C ≤ TA ≤ +125°C subgroups type VSY = ±2.5 V, VCM = 0 V unless otherwise specified Min Max Input characteristics Offset voltage VOS 1 01, 02 35 µV 2, 3 65 M,D,P,L,R 1 01 35 D, P, L 1 02 35 Offset voltage drift 3/ ∆VOS/∆T 1, 2, 3 01, 02 0.3 µV/°C Input bias current IB 1, 2, 3 01, 02 -1 +1 nA M,D,P,L,R 1 01 -1 +1 D, P, L 1 02 -1 +1 Input offset current IOS 1 01, 02 -0.5 +0.5 nA 2, 3 -1 +1 M,D,P,L,R 1 01 -0.5 +0.5 D, P, L 1 02 -0.5 +0.5 Input voltage range 4/ IVR 1, 2, 3 01, 02 -1.3 +0.5 V M,D,P,L,R 1 01 -1.3 +0.5 D, P, L 1 02 -1.3 +0.5 Common-mode rejection ratio CMRR VCM = -1.3 V to +0.5 V 1 01, 02 122 dB 2 87 3 120 M,D,P,L,R 1 01 122 D, P, L 1 02 122 Large signal voltage gain AV RL = 2 kΩ, 1 01, 02 121 dB VOUT = -0.5 V to +0.5 V 2, 3 120 M,D,P,L,R 1 01 121 D, P, L 1 02 121 See footnotes at end of table.
STANDARD
SIZE
5962-14233 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 A 6 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
