Datasheet ADA4077-2 (Analog Devices) - 8
Description | 4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Dual Amplifier |
Pages / Page | 21 / 8 — STANDARD. 5962-14233. MICROCIRCUIT DRAWING |
File Format / Size | PDF / 350 Kb |
TABLE IA. Electrical performance characteristics – Continued. Test Symbol Conditions 1/ 2/ Group A Device Limits Unit -55°C ≤ TA ≤ +125°C subgroups type VSY = ±2.5 V, VCM = 0 V unless otherwise specified Min Max Dynamic Performance Slew rate 3/ 6/ SR+ RL = 2 kΩ 4 01, 02 1.2 V/µs 5 1.8 6 0.74 SR- 4 1.19 5 1.55 6 0.7 Settling time 0.1% 3/ 6/ +tS VIN = 1 V step, RL = 2 kΩ, µs 9 01, 02 2.9 AV = −1 10 2.4 11 3.3 -tS 9 2.9 10 2.5 11 3.4 Gain bandwidth product GBP VIN = 10 mV p-p, RL = 2 kΩ, MHz 4,5,6 01, 02 2.9 AV = +100 M,D,P,L,R 4 01 2.9 D,P,L 4 02 2.9 −3 dB closed-loop bandwidth −3 dB AV = +1, VIN = 10 mV p-p, MHz 4,5 01, 02 6.8 3/ 6/ RL = 2 kΩ 6 3.8 Voltage noise 3/ 6/ en p-p 0.1 Hz to 10 Hz 4 01, 02 0.35 µVp-p 5 0.75 6 0.6 Voltage noise density 3/ 6/ en F=10 kHz 4 01, 02 6.9 nVp-p 5 8 6 6.3 See footnotes at end of table.
STANDARD
SIZE
5962-14233 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 A 8 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
