Datasheet ADA4528-2 (Analog Devices) - 3
DescriptionPrecision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp
Pages / Page16 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16615
File Format / SizePDF / 141 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16615
1.3 Absolute maximum ratings. 1/ Supply voltage (VS) .. 6 V Input voltage (VIN) ... VS 0.3 V Input current ... 10 mA 2/ Differential input voltage ... VS Output short circuit duration to GND .. Indefinite Power dissipation (PD) with TJ under +150C .. 400 mW Lead temperature (soldering, 60 seconds) ... +300C Storage temperature range (TSTG) .. -65C to +150C Junction temperature range (TJ) .. -65C to +150C Thermal resistance, junction to case (JC) ... 3.9C/W Thermal resistance, junction to ambient (JA) .. 52C/W 1.4 Recommended operating conditions. 3/ Operating temperature range (TA) .. -55C to +125C 1/ Stresses beyond those listed under “absolute maximum rating” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2/ The input pins have clamp diodes to the power supply pins. Limits the input current to 10 mA or less whenever input signals exceed the power supply rail by 0.3 V. 3/ Use of this product beyond the manufacturers design rules or stated parameters is done at the user’s risk. The manufacturer and/or distributor maintain no responsibility or liability for product used beyond the stated limits.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16615
REV PAGE 3
