Datasheet ADA4528-2 (Analog Devices) - 8
DescriptionPrecision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp
Pages / Page16 / 8 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16615
File Format / SizePDF / 141 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16615
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit VS = 2.5 V, VCM = VS/2 TA type unless otherwise specified Min Max Noise performance Voltage noise enp-p f = 0.1 Hz to 10 Hz, AV = +100 +25C 01 97 typical nVp-p Voltage noise density en f = 1 kHz, AV = +100 +25C 01 5.6 typical nV / Hz f = 1 kHz, AV = +100, VCM = 2.0 V 5.5 typical Current noise inp-p f = 0.1 Hz to 10 Hz, AV = +100 +25C 01 10 typical pAp-p Current noise density in f = 1 kHz, AV = +100 +25C 01 0.7 typical pA / Hz See footnote at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16615
REV PAGE 8
